SAS question, because we need more SAS.
by BrandonB » Thu Aug 10, 2017 1:55 pm
Can i get away with using stock drive shafts into a dana 60 and gm 14 bolt?
Thanks dudes.
BrandonB
by Diacom » Thu Aug 10, 2017 9:31 pm
If you find the appropriate u-joints I suppose you could.
But the length will be a problem after you figure out how to get them to mate to the axles. You'll have to have them lengthened and balanced anyways, might as well have the appropriate yolks put in place so you don't have such small caps on one end and larger on the other so to speak.
by HARDTRAILZ » Fri Aug 11, 2017 10:43 am
Not in stock form and driveshafts are pretty cheap in the whole equation of a SAS.
by Shrutiii » Wed Jan 01, 2020 6:46 am
Hi!
hope we have great discussion ahead!!
Banned
Shrutiii
by ErikSS » Sun Jan 05, 2020 12:05 am
It's technically possible. But Very unlikely. The length and yoke are likely different. The CV style of the front shaft is very limiting as well.
All in all, it would be crazy to try to design around a driveshaft. Much better things to worry about.
by HARDTRAILZ » Sun Jan 05, 2020 12:20 am
Holy 2017
Return to Off Road Discussion
