Fuel mileage.
by Cable810 » Mon Dec 08, 2014 11:07 pm
I got a quote of 300-500 with me providing the gears and rebuild kit
by HARDTRAILZ » Tue Dec 09, 2014 9:30 am
Rear diffs are 225 round here and front I never priced but I would imagine the extra work work be a good bit more for removal and reinstall
by Trailblazin Ahead » Fri Jan 16, 2015 4:17 pm
255/75r16, 3.42 gears. Have exhaust and CAI gets 15-17 in stop and go, 70 on freeway 18-21 depending on my foot
Trailblazin Ahead
by Anthony Hernandez » Sat Jan 17, 2015 3:25 am
07' 3.73 gears, limited slip, 255 75r17 bfg mt's, maybe 11 highway if I'm really feathering the //// pedal :/
by Grimor » Sat Jan 17, 2015 1:29 pm
before i swapped the bigger tires and rear, i got 22 mpg highway...
now I'm getting 13.4 city/highway and 11 in 4high on snowy roads. (doing donuts in the yard all weekend may of influenced the 11mpg)
the 4.10 gearing kinda hurts at 70mph
Grimor
Rank: Driveway Rated
by HARDTRAILZ » Sun Jan 18, 2015 2:50 pm
4.10s give better mpg than 3.73 at 70
by Moots1288 » Sun Jan 18, 2015 3:00 pm
I dont go 70 MPH often in NYC but I can 100% see a difference between 3.73s and 4.56s on 33's I got about about give or take 3 mpg since.
by Jrgunn5150 » Wed Mar 04, 2015 3:57 pm
I've been getting a steady 14.5 no matter what since I bought it two months ago. 5.3, 3.42, 245/7/17
by Whitelightening » Tue Jul 21, 2015 4:52 pm
I get a steady 15.2...I guess it's not that bad
Whitelightening
by Jrgunn5150 » Tue Jul 21, 2015 5:02 pm
I changed my hubs and its climbed to 15.6 over the past few days.
I have new plugs and wires en route, it may go even higher lol
by mason10198 » Thu Dec 31, 2015 7:13 pm
33" tires, 3.42 gears. Dont know weight. 13 MPG city. I haven't gone more than 20 miles interstate at a time since I bought it. I think I was getting around 15-16 when I had the stock wheels/tires but I didn't have the scangauge to tell me instantly yet.
by NC_IslandRunner » Thu Dec 31, 2015 7:54 pm
33s with 3.42 gears, you are high risk of breaking something offroad.
by mason10198 » Thu Dec 31, 2015 8:16 pm
NC_IslandRunner wrote:33s with 3.42 gears, you are high risk of breaking something offroad.
Are you just talking about powertrain? I always use low range unless I'm on flat ground to keep it from stressing too much.
Sent from Tapatalk
by Shdwdrgn » Thu Dec 31, 2015 8:45 pm
That doesn't protect anything after the transmission though. You're still running a low gear ratio to a large tire, and requiring the drive shaft and rear axle to take the brunt of the torque.
Shdwdrgn
Contributing Author
by Rickalicka18 » Thu Dec 31, 2015 9:11 pm
255/75/17 is a 32.06 tire not 33"
Rickalicka18
by mason10198 » Thu Dec 31, 2015 9:28 pm
Rickalicka18 wrote:255/75/17 is a 32.06 tire not 33"
depends on brand. tire guy told me that my specific tire comes out to about 32.7 at 40psi. although he could very well have been wrong.
Sent from Tapatalk
by Rickalicka18 » Thu Dec 31, 2015 9:39 pm
Only way to know would to measure it i guess haha
Rickalicka18
by Rickalicka18 » Mon May 16, 2016 9:41 am
18.7mpg with 265/70/17 tires and 3.42 gearing. Don't know how I did it... I was really just driving normal around the city/backroads.
Rickalicka18
by Cable810 » Mon May 16, 2016 12:48 pm
I've been avg between 10 and 13mpg. the avg seems to be around 11
by HARDTRAILZ » Wed May 18, 2016 12:34 pm
I kept a good eye on the MPG for this past weekends adventures. I filled up and drove 180 miles with half at 60ish and the rest 75ish mph. Scan said 16.1 mpg on arrival. I put ten gallons of fuel in for the trails. Leaving Sunday I was at 260 miles and needed an additional 9.9 gallons to fillup. That put the mixed driving right at 13 which I though pretty good for some well used low range over the trails. I drove the 180 miles home at 65 due to Matt not having OD and him following me. I showed 17.2 for that trip. I have repeatedly seen my scangauge to be an accurate reflection of hand calculations so i trust it with .5 mpg either way. Pretty happy overall with the setup currently.
