The Best Ways to Mount to the TB Roof
by Trail X » Mon Apr 05, 2010 11:06 am
This is something that we've all thought about when designing/mounting a roof rack.
There are many ways of going about this... here are a few I have seen/heard of so far:
  • JB welding a nut to a plate
  • Using a square-holed square washer with a carrier bolt
  • Bolting through the entire rack
  • Screwing into the roof rack mounting holes
  • Using a wood screw into the roof rack
  • Making your own mount
Lots of options...
So even if I listed your idea here, please explain your method fully and provide pictures/etc.
Let us know if it's worked for you and what you would do differently if done again.
Any pictures of long-term results?
I'll chime in with my own ideas/experiences in a bit... :fro:
by Gordinho80 » Mon Apr 05, 2010 11:37 am
Spring Nuts...
I've picked up a few 3/8 spring nuts from Home Depot. They measure 1.375" x 0.75". The rails are slightly angled, 1" at the top and approx. 0.92" at the bottom. So a slight taper...
I plan on grinding down the spring nuts to that they fit snug in the rails.
Attached is a pic of approx. how much grinding would need to be done.
(17.89 KiB) Downloaded 956 times
by Trail X » Mon Apr 05, 2010 1:00 pm
I've done mine two different ways so far...
First was the roof lightbar setup:
It was a nut that was JB-welded to the bottom of a 1" wide aluminum plate.
It works fine for light weights, but the JB-weld isn't as strong as I'd hoped. Mine has cracked and been re-welded a few times. PITA. Although the system does seem to otherwise work fine for light loads. For heavy loads I would be concerned that it could slip within the roof rack channel.
Second was the roof rack setup, which was an improvement:
This used a carrier bolt inserted into a square washer with a square hole. This is permanently housed in the roof rail for easy on/off of the roof rack. The key here to carrying the heavy loads is the rubber. The rubber increases the friction between the rack components, so the only stresses that the carrier bolts see are tension. All lateral loads are transferred through the rubber.
It works well, but I wonder if there is a more elegant solution...
by janesy86 » Mon Apr 05, 2010 1:27 pm
I just took off my lightbar since I haven't really been using it and while unbolting it my JB weld cracked on both sides and the bolts were just spinning so I had to bang it off with a hammer...
But like you said its fine for lighter loads.
by Saxis » Mon Apr 05, 2010 1:47 pm
For something like the lightbar, would it be possible to take a stock crossbar and drill through it to mount the lights? I know the stock crossbar is composite or something, so not sure if it would crack or not...
Saxis
by The Roadie » Tue Apr 06, 2010 12:47 am
I can't be happier with a solution that can't be stronger unless I added more rivnuts to the roof. Just take the entire rack off, drill through the bottom of the metal rails, and go upwards with hardened 5/16" bolts. I worry about other stuff before I worry about 500 pounds of overloaded roof rack flying off the vehicle. After my first two experiments with rectangular nuts failed by starting to loosen up, I just said ENOUGH IS ENOUGH and jumped all the way to bulletproof. Non-adjustable.
by KE7WOX » Wed Apr 07, 2010 12:44 am
Hey Mario, did you find those in the hardware section with all the bolts and nuts?
by Gordinho80 » Wed Apr 07, 2010 12:49 am
They were actually in the electrical section at Home Depot...
by KE7WOX » Wed Apr 07, 2010 7:11 pm
k thanks.
by bgwolfpack » Tue Apr 13, 2010 2:10 pm
Just want to throw this out. I found, what looks to be a good maker of light bars. http://www.carr.com
Has anyone used this product?
by irishboy02 » Tue Apr 13, 2010 6:18 pm
Wow i like those. Will these mount into the tracks on the roofrack or will the attach into the doors like it shows in the picture?
2003 GMC Sierra z71
7" FTS lift
irishboy02
by bgwolfpack » Wed Apr 14, 2010 1:49 pm
If you're new here be sure to check out the AlekG blog site for another option and other ideas. :coffee2:
by Jon A » Sun Nov 28, 2010 12:16 am
In shopping for a roof rack, I wanted something big, strong but low profile (garage fitment issues). Although Baja recommends the standard Mule for Trailblazers, I was convinced the Mega would fit better and I needed the space.
It did look pretty lousy just mounted to the stock crossbars:
But with the custom brackets it looks nearly made for the vehicle:
<SNIP>
I made the brackets from 3/4" square tubing and 1/2" clamps (both from McMaster):
They fit inside the tracks but you do have to spread them a bit--so don't use this method if you want to use the stock crossbars in those locations in the future.
With six total locations and a direct loadpath you have many times the strength of the stock setup. Do a better job of prep and paint on them that I did though as you can see a bit of rust on mine already...I'm going to have to take those off and hit them again.
Reason: COPIED THREAD INTO THIS TOPIC FOR FUTURE SEARCHING PURPOSES
Jon A
by jolly01 » Mon Dec 06, 2010 9:17 am
I have a kayak rack idea knocking around my head. I made my measured drawings (would upload, but the scanner is packed) I will post pics and updates as I go through the fab work. Think of a clamp for the factory cross rails, a vertical riser, and horizontal rollers like the chassis of an old roller skate. That is the best way I can describe it.
Heaven on Earth is Hell on wheels
jolly01
by dirty anton » Tue Dec 07, 2010 12:55 pm
with the surco roof rack to me it sat too tall with their mounting brackets with a tire up there. so i got some flat metal stock and bent and cut my own brackets with 3 holes drilled through them. i used the threaded squares that came with the surco mounting kit. got 8 bolts med and 4 bolts long and bolted it(lock washers) to the track. the 4 long bolts go through the existing strap and holes that hold the rack together then drilled through bottom of surco rack and bolted in to threaded square in existing roof track.hope this does not confuse :scratch:also there is now 3 bolts at all four corners compared to 2 bolts that come with the surco kit. the rack now sits flat on the trucks rack. alot sturdier. i just check the bolts every month,no problems at all.
(12.03 KiB) Downloaded 580 times
(11.67 KiB) Downloaded 580 times
(11.47 KiB) Downloaded 580 times
dirty anton
by dirty anton » Tue Dec 07, 2010 12:59 pm
home made brackets
(9.49 KiB) Downloaded 580 times
(12.84 KiB) Downloaded 580 times
dirty anton
by jolly01 » Sun Dec 12, 2010 2:42 pm
jolly01 wrote:I have a kayak rack idea knocking around my head. I made my measured drawings (would upload, but the scanner is packed) I will post pics and updates as I go through the fab work. Think of a clamp for the factory cross rails, a vertical riser, and horizontal rollers like the chassis of an old roller skate. That is the best way I can describe it.
I just done my materials pricing and I can bring this in for less than $50.00!
jolly01
by jolly01 » Mon Jan 03, 2011 11:23 pm
Had to change the plan like five times, but we finished up the Fab work and tried a dry fit. Looks good just a little high. The camera batteries were dead. Pics will be posted by the weekend. The paint work should be done by then.
jolly01
by jolly01 » Tue Jan 11, 2011 10:43 am
When the weather warms back up I am going to redo the finish, but they work well for now.
Here is a shot from the back. The rollers flip to near vertical to help with the intial lift.
once the boat is up the front saddles are a non slip coverd foam to prevent the boat from going to far forward and onto the hood
The next thing to do is trim down the front a little and that should allow a full raising of the rear gate.
I replaced the factory cross bars with 1 inch square tubing. I was afraid that the factory rails would not be strong enough. The boat rack is actually four peices that slip on and simply bolt on. A moderatly easy mod saving over $100 from buying a similar set up that may not even clear the lights.
jolly01
by v7guy » Tue May 12, 2015 4:34 am
Looks pretty alright! How much have you used it so far?
