Protection Day....Thanks Mike
by The Roadie » Mon Mar 22, 2010 10:54 pm
Here's the kind of noob I was five years ago with nobody as a mentor. Was on an organized trail run with a group that required tow hooks, and Envoys didn't come with 'em. OMG, what a goof. 10,000 pound tow hooks on a 50 pound capable location. :slap:
by HARDTRAILZ » Tue Mar 23, 2010 12:23 am
Got to learn somehow. I bet it seemed like the perfect solution at the time.
by HARDTRAILZ » Wed Mar 31, 2010 11:57 pm
Added some bolt head protectors and got some paint on the skids yesterday and today....
The paint
The oil skid powdercoat was already chipped off so I painted both sides to prevent rust
The radiator skid with a bunch of runs but its a skids plate and i wanted to get paint in all the holes, so it is thick in spots
And the mess from dropping the open can
by irishboy02 » Thu Apr 01, 2010 2:02 am
Smart idea. I resprayedd my front impact bar (bumper is removed) cause it was starting to oxidise, sanded it and rustoleum flat black spray, nvr dealt with the actual can paint.
Looks good and def needed. :cheers:
2003 GMC Sierra z71
7" FTS lift
irishboy02
by janesy86 » Thu Apr 01, 2010 7:40 am
Nice! Lookin' good... did you just use a roller to apply the paint?
by bartonmd » Thu Apr 01, 2010 8:01 am
Lookin Good!
by HARDTRAILZ » Thu Apr 01, 2010 8:19 am
Oh Yeah...Mike I did knock those two front corners off with the sawzall and ground it smooth, so when I re-install I will let you know if it fixes the minor issue.
I used a foam brush on one side and a regular 99 cent paint brush on the other. The regualr one worked better. I thought of rolling, but i wanted to get in the welds and the holes and with the brush you can kind of stab the bristles into the nooks and crannies so its all coated.
by bartonmd » Thu Apr 01, 2010 8:40 am
HARDTRAILZ wrote:Oh Yeah...Mike I did knock those two front corners off with the sawzall and ground it smooth, so when I re-install I will let you know if it fixes the minor issue.
Awesome, thanks! I know it's needed for the regular bumper mounting, though, so it'll get done to all of them (or rather, I'll change the design)
Thanks,
by HARDTRAILZ » Thu Apr 01, 2010 8:48 am
I will be reattaching it today, so i will see if i did enough or if i need a shade more.
by janesy86 » Thu Apr 08, 2010 4:19 pm
I searched everywhere and for the life of me couldn't find the thread where you painted you sliders with this paint. Just wondering how many cans you went thru and if you also just used a brush on them as well. Plan on tackling mine this weekend and would rather not run out... Thanks in advance. :cheers:
Edit: Found it on the OS that you brushed it on, don't think this update was posted here. I thought I was :gimp: lookin for it, but still wondering the quantity of cans..
by HARDTRAILZ » Thu Apr 08, 2010 10:55 pm
I used a quart for everything..including the spill. It was 10 bux or right around there. I have one thick coat on everything, but will be doing another here soon and will need a second can since the garage swallowed some or I would have had enough.
