Panhard Bar Drop Bracket
by Moots1288 » Mon Oct 14, 2013 10:08 pm
ErikSS wrote:I do like this better.
looks much better
by Trail X » Mon Oct 14, 2013 10:21 pm
Is the top bolt sleeved between the mounting holes?
If not, there really needs to be. In some pictures it looks like there is one, and in others it looks sleeveless.
If so, I'd cut the sleeve down a bit and put a washer on either side of it, internal to the bracket. That thin sheet metal doesn't have much bearing surface, and I could see it wearing some - mainly because of the constant vibrations. Might not be a big deal, depending on the thickness of the sleeve.
I'm less worried about it now though, with the bar moved. Glad the holes worked out.
by ErikSS » Tue Oct 15, 2013 10:03 pm
JamesDowning wrote:Is the top bolt sleeved between the mounting holes?
Yes, it's sleeved. I will look, but when I bolted it together I was not concerned with the metal on the outsides of the sleeve. There should not be any notable motion there.
by ErikSS » Thu Oct 17, 2013 9:50 pm
After driving it for a few days, I checked again. I seem to be about 1/8" towards the passenger side still. That's a whole lot better than the aprox 1 1/2" that I was off! We should find ou this weekend how it holds up to abuse at the Badlands!
by markmc » Fri Oct 18, 2013 3:31 am
Awesome!
i have one more sample with changes ready for Moots..
markmc
Rank: Mall Rated
by ErikSS » Sun Oct 20, 2013 8:55 pm
I just got back from the Badlands. The mount held up perfectly. It didn't move, slip, bend or fatigue in any way I can find. It looks just like the day I put it on. It's not there yet, but I would imagine it will only be a few days before some video and picture proof of it's durability will be on the Completed Badlands thread.
viewtopic.php?f=57&t=4727
by Moots1288 » Wed Oct 23, 2013 6:30 pm
by markmc » Thu Oct 24, 2013 2:17 am
The bushing is correct..it looks narrow cus it fits in the original bar mount..the bracket fits over/around the original bar mount..
markmc
Rank: Mall Rated
by Moots1288 » Wed Dec 18, 2013 9:28 pm
I've had mine installed for a month or so now, and havent had any problems.
I Installed the cross bar to the same mounting hole as the panhard bar as was stated. It definitely helps support the mount
by Cable810 » Wed Mar 26, 2014 3:59 pm
Anymore word on theses Mark?
by markmc » Thu Mar 27, 2014 3:25 am
Cable810 wrote:Anymore word on theses Mark?
All the tooling is ready for production start.
Hit me up if you need one.
been busy working on other products..
btw, Sad to report: 3" body lift has been discontinued due to supplier issues..
markmc
Rank: Mall Rated
by Moots1288 » Fri Mar 28, 2014 9:28 am
Mine has been holding up alright, no problems. Have to get under there a hit it with the rattle can though after I was the rest of the salt off from the year.
by v7guy » Wed Apr 23, 2014 2:40 am
Just revisiting this, how many guys are using this now?
Mark, have you given any additional thought to lowering the bar another couple inches to get it closer to the same plane that the axle sits? The gains are minimal, but it may help the guys running 35s by lessening the angles even more. A slightly longer support brace could be made easily, piece of tube, then hammer flat the ends and drill a hole.
by Cable810 » Wed Apr 23, 2014 9:43 am
I'm guessing there are 4 running this. ErikSS, Moots, Me and Lauron.
by markmc » Wed Apr 23, 2014 5:01 pm
Cable810 wrote:I'm guessing there are 4 running this. ErikSS, Moots, Me and Lauron.
Correct, 4 are in service.
With varying results, i am putting the product on production hold until i figure out what changes need to be made..
markmc
Rank: Mall Rated
by RONVOYO2 » Sun Apr 27, 2014 7:56 pm
NOW THERE ARE FIVE IN SERVICE. I FINALLY GOT MINE INSTALLED TODAY. INSTALLATION WAS PRETTY MUCH CUT AND DRY EXEPT THAT ON MY ENVOY THE CROSS MEMBER LINED UP WITH THE END OF THE SPARE TIRE REST AND I HAD TO CUT ABOUT A HALF INCH OFF THE END. THE PANHARD BAR IS ALMOST LEVEL, STILL HIGHER ON THE PASSENGER SIDE, AND THE TIRES NOW FAVOR THE DRIVERS SIDE ABOUT A QUARTER OF AN INCH. I THINK THE CHANGE TO STICKING OUT THE DRIVERS SIDE HAS SOMETHING TO DO WITH USING THE ORIGINAL CROSS BAR ON THE LOWER HOLE WITH THE NEW LOCATION OF THE PANHARD BAR. I THINK IT ACTUALLY PULLS THE NEW BRACKET TOWARD THE DRIVERS SIDE SLIGHTLY MAKING EVERYTHING SHIFT JUST A LITTLE MORE THAN WE ACTUALLY NEED. ITS STILL MUCH BETTER THAN WHAT I STARTED OUT WITH AND IM HAPPY WITH THE END RESULT. THANKYOU MARK.
RONVOYO2
by Diacom » Sun Apr 27, 2014 8:18 pm
Any reason your shouting?
by Cable810 » Sun Apr 27, 2014 8:29 pm
RONVOYO2 wrote: I THINK THE CHANGE TO STICKING OUT THE DRIVERS SIDE HAS SOMETHING TO DO WITH USING THE ORIGINAL CROSS BAR ON THE LOWER HOLE WITH THE NEW LOCATION OF THE PANHARD BAR. I THINK IT ACTUALLY PULLS THE NEW BRACKET TOWARD THE DRIVERS SIDE SLIGHTLY MAKING EVERYTHING SHIFT JUST A LITTLE MORE THAN WE ACTUALLY NEED. ITS STILL MUCH BETTER THAN WHAT I STARTED OUT WITH AND IM HAPPY WITH THE END RESULT. THANKYOU MARK.
This actually could explain a lot. Especially with the cross bar pulling towards the driver side which I see happening on mine. How much lift you have any z71s or Skyjacker Coil Springs? If you give us that It might narrow it down. Once I get my disco rebuilt I'll give this a try and see if it changes it for the better.
by RONVOYO2 » Sun Apr 27, 2014 10:18 pm
Ill try and not shout this time. I've got the usual 3 front and 2 rear level lift with stock rear springs and bds shocks. Rear sway bar delete. Does that help.
RONVOYO2
by Cable810 » Mon Apr 28, 2014 10:05 am
Yes. Do you have before and after measurements??
