He was able to come over Sunday and we got The Template accomplished.
The design is going to be different than the way Mike has his. Its going to bolt the same way Mikes does at the Oil Skid Plate. Then it will have a 20 Degree bend after 9" bolting to the Oil Skid. But instead of havin it bolt with the tow hooks we decided to bring it up and bolt to the front of the bumper. This might change due to the possiability of a tube bumper.
Tho whole design of the skid plate will be something like this:
Dimentions are 27"Width x 40"Length using 3/16" steel. Bolt Protectors, and holes allowing air to flow will be added. We are also going to add some supports in the skid for added strength. For a 5'x5' sheet of 3/16" steel is $150+tax. Sadly no local junyards keep anything project worthy... So he is goin to check places in Indy where he got most of his stell while living in Indy.
He metioned that he has talked to Kyle a few times when he was living in the Indy Area.
. The skid plate is done. Now this design probably isn't the best but its taken a decent hit when I was climbing Marble Head Steps on Drummond, it just bent a bit and didn't make any contact with anything under the vehicle. Here is a link to the video of me climbing Marble Head Steps when I but the dent in the skid
