Pipe/tube fish mouth program
by v7guy » Fri Dec 21, 2012 4:56 pm
I've used this a few times, seems to do a pretty alright job. You input the tube/pipe diameter and wall, then the angle of fit up and then it prints out a paper template so you can easily cut it out with a 4.5" grinder. You have to download the file and run it. Thought I would share.
http://www.ozhpv.org.au/shed/tubemiter.htm
by JMHinAZ » Sat Dec 22, 2012 12:12 am
Is this something you might use if you were going to put in a roll cage? Thanks btw
JMHinAZ
by dvanbramer88 » Sat Dec 22, 2012 12:46 am
v7guy wrote:I've used this a few times, seems to do a pretty alright job. You input the tube/pipe diameter and wall, then the angle of fit up and then it prints out a paper template so you can easily cut it out with a 4.5" grinder. You have to download the file and run it. Thought I would share.
Is this part of your "big plans" for the future?
by v7guy » Sat Dec 22, 2012 2:14 am
You could use it for fitting up a roll cage, sure. Basically anything where you're going to be fitting up tube or pipe.
It's a lot more work than using a tubing notcher, but it works well for smaller jobs.
Dave, I have no big plans, what do you speak of? Best move along, nothing to see here. lol
