by Trail X » Tue Aug 02, 2011 9:05 am
I've really tried to tune in my driving habits over the last few years. I have a 17 mile commute, so I have had a lot of time to try and determine what works and what doesn't (for me at least). First of all - I've found that cruise control will really kill gas mileage so I only use that on long flat straightaways. I also don't tend to exceed 70 mph and normally cruise at about 65-68. However my commute is around a beltway, so my max speed there is 60 or so.
The other 'trick' I have begun to use has to do with the scangauge. If you watch the manifold air pressure (MAP), you can peg 4th gear going up a hill without unlocking the torque converter clutch (TCC). This helps in two big ways. IC engines are more efficient when operated at low intake vacuum levels due to the fact that they have to work less to suck the air into the combustion chambers. Second, by unlocking the TCC, you would otherwise lose energy into the torque converter. I've found for my vehicle that it will unlock the TCC at about 14.2 psi MAP, so I will tend to lock in the throttle at 14.1 psi and cruise up the hill (normally losing some marginal speed) without unlocking the TCC.
Also - I'm working off of adjusted gasoline and speed values (for larger tires) based on actual gasoline used at the pump, and gps speed. So if you're using the built in DIC for your gasoline consumption, it could also be estimating a bit low because it isn't tuned in exactly.
Terrain will also greatly affect mileage... rolling hills seem to do me well, but when I'm heading through WV, my numbers will drop pretty good due to the mountain climbs and change in elevation.
Sorry you guys are getting such low numbers... hopefully this helps you a bit.
