Thank´s Mike you have reminded me to install my rear recovery points
Thank´s for more work, i can tell you my wife won´t be happy about that.
So this is another reason to remove the rear bumper plastic part to install the damper AND the recovery points and take some measurements from what´s behind the bumper for the tire carrier. Have I already told that the complete rear tire carrier is bolted to the frame? Nothing is welded to the frame that way it can be easily swapped to another TB.
I have borrowed a picture from AlekG, HE HAD THE IDEA FOR THE REAR RECOVERY POINTS! So here is the picture I really like:
When I saw that picture I liked the fact that it looks functional and factory clean. The tire carrier was not what I have liked so I had to do it my way. But the Idea for the recovery points is excellent. I don´t wanted to bold / screw it to the bumper so I found another kind for attaching the recovery points with drilling only one hole for each recovery point.
Here is a picture of what I got and haven´t installed so far:
These recovery points can turn in the drilled hole and are secured with the retaining ring.
Simple installation one hole for every recover point drilled in the reinforcement bar. This is the view from behind on the reinforcement bar. Holes will be drilled to the left and the right parts that go into the rear frame of the TB.
That´s the idea.
Karsten
