Rear Bumper+ Tire Carrier
by Hpimichael02 » Mon Jan 24, 2011 3:50 pm
hey guys,
i have a couple this in the fire but this is #2 on my list...
so i have plans on building a rear bumper + tire carrier, after the body lift i dont want to cut the frame and such so ima keep everything down at normal level and build around it and brace everything to that so it will be all one piece...
here is a crap picture of the base product super simple of the bumper
the circles will be reverse/ rear fogs and the square will be my tow hitch....
a 3D design will be ready tonight and the templates on the truck tomorrow and maybe start cutting the metal wed
the bottom piece that says top shelf will be the shelf on the bumper as a step
Hpimichael02
by bartonmd » Mon Jan 24, 2011 4:27 pm
Cool! Keep updating this as you get it built!
by HARDTRAILZ » Mon Jan 24, 2011 4:29 pm
I like it.
by janesy86 » Mon Jan 24, 2011 4:34 pm
Nice! Keep us updated!
by Trail X » Mon Jan 24, 2011 5:20 pm
Good luck. On paper it looks simple... but let me give you a piece of advice... start with the frame mount. Once you get that designed, start to build out. Everything falls into place that way.
by Hpimichael02 » Mon Jan 24, 2011 5:34 pm
James: thanks for that advice...ill def start with that area...
ive been drawing it up while at work today ... and on break measureing here and there.. i have all the materials at home from my brother body drop so im set with that... but i think the hardest part is mounting the tire carrier to the frame and keeping everything super strong ....
its easy to make a janky POS but hard to make something strong and beautiful
Hpimichael02
by Hpimichael02 » Tue Jan 25, 2011 1:29 pm
What's the best material for templates cardboard or foam bored?
Hpimichael02
by Philberto » Tue Jan 25, 2011 1:48 pm
Foam board tends to have more rigidity and is usually thicker. I recommend this.
by djthumper » Tue Jan 25, 2011 3:33 pm
I have usually used cardboard for templates, foam board can work but not always as sturdy when you go to trace it out. Are you using it for mock-up also?
by Hpimichael02 » Thu Jan 27, 2011 10:49 am
Here's the driver cornerneed to redo a couple angles
That's the idea I'm running with right now, gonna make it all one piece that's the plan
Hpimichael02
by bartonmd » Thu Jan 27, 2011 11:00 am
FWIW, you'll want to leave ~3/8-1/2" between your bumper and the body... You don't notice it with the plastic facias, but the frame/bumpers move slightly seperately from the body; so you'll want to give a little bit of breathing room there, so you don't rub the bumper on the body.
by Hpimichael02 » Thu Jan 27, 2011 12:59 pm
10-4 thanks man for that advice. i woudl never of thought of that
if i continue with this set up the angle corner piece's are eithere gonna be storage unit's for straps and recoevry stuff or where my rear fogs will be located at
Hpimichael02
by janesy86 » Thu Jan 27, 2011 5:55 pm
Looks like a pretty cool design! Keep the progress updates coming as you work on this.
What are you doing for the tire carrier? One of those DIY hinge kits?
by Hpimichael02 » Thu Jan 27, 2011 6:46 pm
it might be duel tire carrier- a fold sideways and down(fold side ways to clear the tail gate on one side .. that as of yet has to be designed but it will be going straight through and welded and bolted to the actual frame on each frame rail-
i will be trying to finish it tonight wheather permitting
now i have a couple thicknesses of metal at the house what should i use?
now keep in mind im kepeing the factory rear hitch and towing capabilities, so all towing mounts will be to that so there will be only wind drag on it and the rear occasion of tree bumping.. so im think .25" is kinda to think for this application- what do you think ... ll happily change the thickness
Hpimichael02
by bartonmd » Thu Jan 27, 2011 7:17 pm
If you're not replacing the hitch, 3/16 is plenty...
by Hpimichael02 » Tue Feb 01, 2011 12:32 am
Metal cut just waiting to weld it
Hpimichael02
by Trail X » Sun Mar 27, 2011 4:52 pm
Hey Mike, did this ever come together? I'd love to see pictures.
by janesy86 » Sun Mar 27, 2011 4:57 pm
Pretty sure he's going down with the TB. Was selling all his stuff in the classifieds. So I'll guess and say that it had not been done.
by Hpimichael02 » Mon Mar 28, 2011 1:19 am
The metal is cut and waiting to be welded, I was selling it but only got hits for the fan clutch , so I just need a full weekend to start mocking the metal up, time is def. Short with working :((
Hpimichael02
