Trailblazer Rear Bumper Design/Build
by glfredrick » Tue Jul 27, 2010 10:43 am
A hit to the air tank would mostly just split a seam and let the air out. No real explosion. Happens all the time on big rigs when they get in accidents. They have air tanks haning all over the place.
glfredrick
Contributing Author
by Gordinho80 » Tue Jul 27, 2010 10:49 am
The bumper is looking amazing! Can't wait to see more progress!
by Hpimichael02 » Fri Aug 06, 2010 8:52 am
Make sure Eric saves the templates cause I want one too
Hpimichael02
by aaronrules » Fri Aug 06, 2010 12:56 pm
Have you had any more progress? I'm anxious to have something else to drool over with your ride dude!
aaronrules
by Trail X » Fri Aug 06, 2010 1:41 pm
aaronrules wrote:Have you had any more progress? I'm anxious to have something else to drool over with your ride dude!
Things have been going a million miles an hour... but not the bumper. Minor progress, but no pictures. I'll get some pictures when Eric and I do a test-fit.
by teebes » Wed Sep 01, 2010 7:22 pm
We need progress pics :drive:
:need pics:
teebes
by Trail X » Wed Sep 01, 2010 9:46 pm
Haha, I know I know!
Trying to get together with Eric sometime soon for a test fitment. Probably next week. Then it's on hold for another 2 weeks due to a business trip.
by Trail X » Sat Sep 11, 2010 12:41 am
FINALLY some free time and movement... forgot the camera, so it's only cell phone pictures. :?
Cut the frame ends so as to fit the bumper in tighter:
(28.4 KiB) Downloaded 414 times
Welded in the receiver (back side shown):
(46.23 KiB) Downloaded 414 times
More various pictures from the day... spent a lot of time making some patterns, measurements, and sketches:
(54.02 KiB) Downloaded 414 times
(48.88 KiB) Downloaded 414 times
(29.04 KiB) Downloaded 414 times
(31.16 KiB) Downloaded 414 times
Hopefully will have more updates in about 3 weeks. :woot:
by HARDTRAILZ » Sat Sep 11, 2010 12:45 am
Got to love cutting the frame for stuff. My rear and front are cut.
I like it, looks alot like my old front bumper. Plenty strong and very functional.
by SteveTB03 » Sat Sep 11, 2010 1:32 am
I love the design and the progress is going good, BUT how is this affecting your towing capabilities with the hitch no longer on your TB? Is the hitch that's built into the bumper has it now been downgraded to like a class 1 hitch instead of a class 3 hitch?
Go Big & Go Broke
SteveTB03
by Zero » Sat Sep 11, 2010 6:31 am
I believe the weight JD's bumper would be limited by how its mounted to the frame, and not that material holding him back. if you think about it, there is about 3x as much steel. And it has to be strong enough for extractions.
But I too would wonder what the answer actually is? And better yet, How will he test it?
by Trail X » Sat Sep 11, 2010 9:42 am
SteveTB03 wrote:I love the design and the progress is going good, BUT how is this affecting your towing capabilities with the hitch no longer on your TB? Is the hitch that's built into the bumper has it now been downgraded to like a class 1 hitch instead of a class 3 hitch?
This hitch is easily stronger than the stock one. I'd feel secure in trailering anything I would with the stock hitch.
We designed it to handle my 8,500 lb winch....
by Trail X » Sat Sep 11, 2010 12:07 pm
HARDTRAILZ wrote:Got to love cutting the frame for stuff. My rear and front are cut.
Those rear frame ends were surprisingly hard ... not enough clearance so we had to use our bandsaw from the bottom... against gravity. Then cleaned it up with a grinder.
Yeah, it does look somewhat similar to your front bumper doesn't it. Sorta a universal shape. This thing is definitely strong as hell (and pretty heavy... already about 60 lbs I'd guess)...
by SteveTB03 » Sat Sep 11, 2010 3:14 pm
Now what exactly did you guys do to make it capable of using a 8500LB winch? Is it mounted far back to the frame or is it just mounted on the tips of the frame kind of like how the stock bumpers are mounted?
Is what your saying just theory that it'll work no problem or did you guys test some things out?
Go Big & Go Broke
SteveTB03
by Trail X » Sun Sep 12, 2010 10:30 am
The frame mounts are deeper and at least 3x thicker than stock. Added an extra bolt deep in the frame. The center section has internal reinforcements - also all thicker and wider than the stock bumper (when you look at the stock bumper, it's not really that beefy).
No actual tests, all mechanical theory and finite element analysis - what I do everyday at work.
by HARDTRAILZ » Sun Sep 19, 2010 2:30 am
SteveTB03 wrote:Now what exactly did you guys do to make it capable of using a 8500LB winch? Is it mounted far back to the frame or is it just mounted on the tips of the frame kind of like how the stock bumpers are mounted?
They are planning for clear duct tape to take up any slack leftover. It will be fine. :finger:
by Trail X » Fri Oct 01, 2010 2:20 pm
Wings finally tacked in place. :excited:
Next comes the tire carrier.
(49.17 KiB) Downloaded 303 times
(44.85 KiB) Downloaded 303 times
by janesy86 » Fri Oct 01, 2010 3:03 pm
Nice progress! And that is definitely a sweet looking bumper!
by HARDTRAILZ » Fri Oct 01, 2010 3:25 pm
Me likey.
Will it be done for Tecore?
by Trail X » Fri Oct 01, 2010 3:51 pm
HARDTRAILZ wrote:Me likey.
Trying. Worked last night with Eric until 1am. I'm pushing him to get it done by then, but honestly it's going to be hard. A lot of work still to go.
