Another hitch mounted spare tire carrier...
by Gordinho80 » Tue Jul 06, 2010 10:01 am
Well... have been working on this off and on for about 1 month... It's still not complete. I plan on cutting down the arm to bring the wheel closer. I figure at the angle, I can shorten the arm by a good 6" or more. I will hopefully be doing that soon. Then I need to get the hi-lift mount on there. Then it needs to be painted or coated.
It's not the prettiest carrier out there, but it most definitely works!
by HARDTRAILZ » Tue Jul 06, 2010 11:17 am
Well done. I wish I had time to finish mine, but I basically have all the parts.
by janesy86 » Tue Jul 06, 2010 12:30 pm
Nice work man! Looks pretty good. :cheers:
You get a welder? And started to weld now?
by Gordinho80 » Tue Jul 06, 2010 12:37 pm
I wish I had done the welding. Welding was done by someone else. I would like to get a welder and practice, but I would want a decent 220v set up and I currently don't have a 220v receptacle at home...
by janesy86 » Tue Jul 06, 2010 12:54 pm
Ahh. Gotcha, still nice tho.
And I wish I had a welder as well. One of my friends does but its tough sometimes coordinating work time, and my dad aslo has one but not fuctional at the moment.
by Trail X » Tue Jul 06, 2010 1:52 pm
:thumleft:
Looks great Mario! What do you have planned for the license plate?
by Gordinho80 » Tue Jul 06, 2010 1:59 pm
Thanks... I'm probably going to go the same route as you and fish... It's simple, yet very effective....
by bartonmd » Tue Jul 06, 2010 2:00 pm
Gordinho80 wrote:I wish I had done the welding. Welding was done by someone else. I would like to get a welder and practice, but I would want a decent 220v set up and I currently don't have a 220v receptacle at home...
Gas dryer??
I always plugged the welder into the dryer plug at the house I rented in college... In my house, I spent the $40 and put in a 220V out let in the garage...
by Gordinho80 » Tue Jul 06, 2010 2:05 pm
bartonmd wrote:Gas dryer??
All appliances are 120v. I plan on running a subpanel in the garage. I have 5 slots open at my main panel that is on the other side of the house. Think a 10 slot panel would be sufficient to do exterior lighting in backyard and 240v in the garage. In time...
by bartonmd » Tue Jul 06, 2010 2:11 pm
They may all be 120V, but I've never seen a house around here that wasn't wired for a 220V dryer outlet... Have you looked behind there to see if there is a plug that's not being used?
by fishsticks » Wed Jul 07, 2010 5:39 pm
bartonmd wrote:They may all be 120V, but I've never seen a house around here that wasn't wired for a 220V dryer outlet... Have you looked behind there to see if there is a plug that's not being used?
:Iagree: I believe even gas dryers are wired 220V these days for the motors. I could be wrong.
Maybe his washer/dryer aren't in his garage. Mine aren't.
At any rate, the carrier looks great Mario.
Reason: Fixed Quote Tag
by Gordinho80 » Wed Jul 07, 2010 5:43 pm
My laundry room is near the garage... but there is not a 240v feed back there. There was no washer/dryer in the house when we bought it, I know there is no 240v outlet back there.... LOL
Thanks, I should be tweaking the carrier a little within the next few weeks... hopefully completing it.
by johnburgelin » Wed Jul 07, 2010 11:01 pm
those wheels look so cool :) I'm looking at getting stock 16" TB's and bedliner-ing them. But those ranier wheels are so cool looking, nice job btw
johnburgelin
by KE7WOX » Thu Jul 08, 2010 7:20 pm
My house only has 220V for the ACs, and for the stairway lights. Yes, stairway lights (I just learned about that a few hours ago). Everything else is 120.
by Gordinho80 » Fri Jul 09, 2010 11:18 am
Well now, back on topic... :poke:
I got the license plate mount in place yesterday. Did just like JD and Fish... 2 aluminum flat bars bolted to the stock plate holes. I opted not to use the push in tabs, rather, I ran bolts through into the hatch. I have not picked up a light or bumpers yet, should be getting those tonight or tomorrow, so its still not 100% legal, but its visible!
I'm hoping to get the tire mounting plate pushed back SOON... I think I can get it back a good 6-7" and still have clearance. I will also be pushing the plate down a little... as you can see from the pic, the tire does block a little of my view... but its not that bad.
by MrSmithsTB » Fri Jul 09, 2010 12:43 pm
Looks good, man. I've been welder shopping, and Harbor Freight has a decent one that lists for @$150. I have a 50% off coupon that I 'm using on it, but still a good deal either way. Worth it once you get the outlet in your garage.
by Gordinho80 » Fri Jul 09, 2010 1:40 pm
Got anymore of those 50% off coupons??? $75 for a welder, even if a crappy one, is good enough to start and learn!
by Trail X » Fri Jul 09, 2010 1:49 pm
Gordinho80 wrote:Image
Looks like my view. Not bad at all dude!
by johnburgelin » Fri Jul 09, 2010 4:49 pm
MrSmithsTB wrote:Looks good, man. I've been welder shopping, and Harbor Freight has a decent one that lists for @$150. I have a 50% off coupon that I 'm using on it, but still a good deal either way. Worth it once you get the outlet in your garage.
Oh jeez, I'd be down for a 50% coupon, where'd you find it?
johnburgelin
by MrSmithsTB » Fri Jul 09, 2010 6:51 pm
Grand opening of a new store by me. Got it in the circular. I think they may still have ads floating in the store. I'll check it out and grab a few if they do for you guys. Doesn't say anything about only being valid at certain stores either.
