Wow 285/50. I was 275/45-20
So you plan to lift and keep your replicas? Do you have the polished ones? Btw, once you go up, make sure you get an alignment asap
irishboy02 wrote:Wow 285/50. I was 275/45-20
Soon as I pass probation in three months, probably the Wrangler MT/R with Kevlar. Assuming I don't read any more negative reviews. I really, really liked the Procomp XTreme MTs, but they chunked badly and only lasted 25-30K. Lots of great trips, but the cost per mile was pretty high. And their Kevlar was only in the tread, not also in the sidewalls like the Goodyears. I'm soliciting suggestions, though - just remember my mission is sand and rocks, not so much mud. And I tend to air down to 18 PSI only, not lower, so I don't have to air back up for the short pavement stretches between some of the Sierra Nevada and Borrego trails. I might also go down to 15" rims this time around - I went from 17 to 16 for the Procomps. Already at 6X5.5" with Fred's adapters. I should start a new thread closer to the time I'll be buying.HARDTRAILZ wrote:now that you got work...What tires are you going for?
HARDTRAILZ wrote:If you find the pics where I had 15x8s on mine they would have been ridiculously wide with tires. The rims stuck out past where my tires stick now and that is a good 2 inches. 4 in backspacing on 15s cleared, but you will sit WIDE. I do like the 15 in price.
The Roadie wrote:Soon as I pass probation in three months, probably the Wrangler MT/R with Kevlar. Assuming I don't read any more negative reviews. I really, really liked the Procomp XTreme MTs, but they chunked badly and only lasted 25-30K. Lots of great trips, but the cost per mile was pretty high. And their Kevlar was only in the tread, not also in the sidewalls like the Goodyears. I'm soliciting suggestions, though - just remember my mission is sand and rocks, not so much mud. And I tend to air down to 18 PSI only, not lower, so I don't have to air back up for the short pavement stretches between some of the Sierra Nevada and Borrego trails. I might also go down to 15" rims this time around - I went from 17 to 16 for the Procomps. Already at 6X5.5" with Fred's adapters. I should start a new thread closer to the time I'll be buying.HARDTRAILZ wrote:now that you got work...What tires are you going for?
Zero wrote:Plus you got to try and see my goodyears in action!
