I would like share one solution for a problem with the 4*4 switch and save money
After read a lot of post regarding to 4*4 issues.
I decide to solve the mine.
And the best thing is that we can save money for this.
Cause here in Mexico the parts and the price are so difficult to find and expensive.
I'm the proud owner of a trailblazer 4*4 EXT LT 2004 (is an old truck but is great for me)
When I bought this truck this had a problem with the 4*4, was not engaging as should be. the led switch most of the times just remains in 2wd or 4low but most part of times just 2wd..
The 4x4 switch was not working and when this get works in to 4low suddenly this change of position by itself to 2 wheels drive.
Then i decide to tear down the main panel To remove the 4x4 switch And try to fix it to save money.
When finally I get the switch I proceed to remove and open the switch to see the problem.
I found the traces in the switch were in short some positions and that was the reason for that the switch always remain in only one position.
the pics are in the reverse order but shows that was the problem.
