Tarsh's build- 2004 trailblazer LT
by tarsh » Mon Dec 09, 2013 9:04 pm
Tarsh's Build
As she sits today
2004 Trailblazer LT 4.2 nonG80 gt5
Drivetrain Specs:
-Lime swap pcm tune
-Cardone CV shafts
-replaced transfercas 3/23/14
-rebuilt entire valve body 6/11/14
-installed mild shift kit
-installed rapid cool trans cooler in series 6/11/14
-rebuilt trans pump 8/23/14
-rebuilt trans early July 2015
-8.6 rear axle upgrade
-front diff swap
-4.10 gear swap
Suspension Modifications:
-Marks 3" Lift
-Installed 89 springs. Gave me around 2.5"
I was not expecting!
-z71 avalanche rear coils+2" spacer+ tie down
-Marks 1.5" wheel spacers
-Front and Rear sway delete
-Bilstine HD struts
-n8030 rear shocks
-Custom rear shock relocation brackets
Exterior Modifications:
-Custom Front bumper(stinger if u will )
-Custom Rad skid plate(in the works)
-Black stripe painted on hood
-offroadTB.com decals obviously
-Trimmed front wheel wells
-Removed all lower plastics(front bumper skin, rocker panel skin, rear bumper skin)
-My personal "plasti shave"
-Extended roof rack
-Custom cross bars
-Custom rear bumper
-Painted mirror covers to match body
-Added tint stripe to windshield
-3' CB antenna mounted above rear tail light
-34/10.5r17 Interco swampers hand cut to perfection
-Rattlecan stock rims
-Jerrycan mounted on rear
-led pods mounted to winch
-DIY limb risers courtesy of overland bound
-overland bound Steele emblem/member number on hood
-relocated winch power head into engine bay
Engine Modifications:
-Gutted engine bay
-Fan shroud delete
-Clutch fan delete
-Custom e-fan set up
-Cat Back straight pipe
-Custom snorkle build
-A/C delete with the dorman bypass pulley
-Supermodualation coil pack spring delete kit
-changed and relocated washer and coolant tanks
Interior Modifications:
-CB radio mount in place of overhead storage
-all time backup camera
-Pulled front carpet
-7" 2 channel full color monitor mounted in dash for camera and realtime engine monitering
Recovery Equipment:
-8500 Winch with custom bumper
-D-Rings welded on rear bumper
-20'x4" snatch strap
-6' treesaver strap
-one 3" locking clevise
Electrical Modifications:
-Switch for 32" light bar
-3" led pods mounted on winch wired off factory fog light switch
Take the path less traveled
tarsh
Name: Nathan Schroeder
by tarsh » Mon Dec 09, 2013 9:12 pm
Stock
my first modifications to the blaze. cut the hoops off the stock bumper. took the front air ram and put it in place of the huge gap under the grill between the bump and the grill
2013-05-20 20.37.12.jpg (109.18 KiB) Viewed 35780 times
stuck with the stock rims. rattle caned them black
2013-06-02 13.19.23.jpg (79.5 KiB) Viewed 35780 times
tarsh
by tarsh » Mon Dec 09, 2013 9:20 pm
onto my custom stinger(brush guard) which mind you was a huge pain in the butt. after hours of "Lame sharpie marking time" as we called it we ended up with this
and of course a little fresh paint
2013-06-16 18.07.35.jpg (85.12 KiB) Viewed 35774 times
now i know it looks alarmingly like HARDTRAILZ strip on his hood but i had to have one. took forever to lay out
2013-06-24 14.19.52.jpg (95.19 KiB) Viewed 35774 times
tarsh
by tarsh » Mon Dec 09, 2013 9:27 pm
now that summer had rolled around we (my brothers and i) rolled doorless all summer. you wouldn't believe the looks i was getting around town.
2013-07-05 19.36.59.jpg (106.42 KiB) Viewed 35773 times
did some custom grill painting and had to make a custom bowtie. which i get lots of likes on
2013-07-17 21.05.01.jpg (60.65 KiB) Viewed 35773 times
finally got marks 2.5" lift in. i was so stoked
2013-07-20 16.04.13.jpg (76.77 KiB) Viewed 35773 times
tarsh
by tarsh » Mon Dec 09, 2013 9:42 pm
onto my custom rad skid plate. bought a piece of simple sheet metel. my brother works at an auto accesory shop and the were trowing away a bumper display mount. in the shape of an "H". i just cut the upper half off and the bolt holes lined right up for me on the bottom side of the bumper. cut some 45's on the ends to prevent some snagging and bolted her on. then i just zip screwed on the plate steel to create a skid
this was my attempt at a rear tire mount without useing the reciver
2013-09-09 20.03.04.jpg (70.06 KiB) Viewed 35767 times
2013-09-12 15.30.34.jpg (82.24 KiB) Viewed 35767 times
i wish i could have kept it but it was a little sketchy goin down the road. all it took was a hammer to get it off. welder was acting up. thank god nobody got hurt.
tarsh
by tarsh » Mon Dec 09, 2013 9:53 pm
after the accident my rear bumper was totally smashed up. i removed the rear skin and pulled out my receiver, which in my case the bumper and the receiver where one(welded from the factory) i cut the bumper apart from my receiver and went wheeln' with the fellas. thats me.... dont know what was goin on. i think my nabe just popped his radiator hose in his exploder.
2013-09-15 22.30.45.jpeg (110.11 KiB) Viewed 35763 times
onto my "plati shave" i haven't seen this on anyone's ride here( inform me if im wrong) but i like it simply because it gets all the mud and salt out and away from the TB. it also gives it a more "aggressive" stance in my opinion
2013-09-20 22.22.14.jpg (50.07 KiB) Viewed 35762 times
tarsh
by tarsh » Mon Dec 09, 2013 10:11 pm
now the rear bumper was a bit tricky. used "C" channel on the lower half and a nice piece of pre bent scrap the old man picked up from somewhere for the top half. after hours of drinking and pondering at the back of of my bumperless blaze we wound up welding the "C" channel directly to the frame since its bent and weak and welded the pre bent stuff to the top half to fill the gap from frame to the hatch to make it look decent. then added some "D" rings for recovery purposes
2013-11-19 20.34.20.jpg (44.71 KiB) Viewed 35760 times
2013-11-19 21.43.57.jpg (66.88 KiB) Viewed 35760 times
the finished product
2013-11-27 16.32.27.jpg (57.2 KiB) Viewed 35760 times
tarsh
by tarsh » Sun Mar 23, 2014 9:10 am
Transfer case replaced.
Took about 7 hours. Took a little while to figure out how to take it out.going back in was easy
tarsh
by tarsh » Mon Mar 31, 2014 12:56 pm
Added winch.
tarsh
by tarsh » Mon Apr 28, 2014 12:55 pm
Extended my roof rack and rid of the ugly Light bar. Mounted lights to the rack
tarsh
by tarsh » Wed Jun 11, 2014 9:47 pm
6-11-14 valve body completely rebuilt. I wasn't getting lock up.
tarsh
by tarsh » Mon Jun 23, 2014 7:24 pm
6/23/14
Installed rear tire swing
tarsh
by tarsh » Mon Jun 23, 2014 7:25 pm
tarsh
by tarsh » Sat Sep 27, 2014 1:48 pm
:awesome: Finally got around to finishing up my front bumper
tarsh
by tarsh » Fri Jan 09, 2015 9:16 pm
New cardone CV shafts with neoprene boots and my 89 springs. Was my project for the day :woot:
This was after the 89s and new cv shafts
tarsh
by tarsh » Tue Feb 10, 2015 7:39 pm
Befor The 89 front could springs. Measurement from floor to oil pan "skid"(junk)
Right around a foot of clearance with balder than bald 32s and the 3" suspension lift
After the 89 spring install. Right around 15". Thanks Dirty bacon
tarsh
