Aries's Build 2.0 - 2002 Trailblazer LS
by Aries » Tue Dec 29, 2015 8:05 pm
Picked up this replacement TB/LS Sport off CL for pocket change(not really but it sounds good). It sat in their driveway for over a year with a blown transmission, no 2nd gear, no reverse, no battery. Trailered it home and the next day I put a battery in, inflated the tires then I drove it to DMV to ran it though inspection. "BAM" it passed :excited: Now to swap everything from the roll over.
SWAPPED IN TRANSMISSION FROM ROLLOVER
NEW TRANSMISSION FILTER & PAN W/DRAIN PLUG
SWAPPED TRANS COOLER
FLUSHED TRANS WITH NEW FLUID
SWAPPED IN 4.56 FRONT & REAR DIFFERENTIALS
REBUILD 4WD FRONT DISCONNECT
INSTALLED NEW REAR PINION BEARINGS AND SEAL
SWAPPED Z71 REAR SPRINGS W/ 2" BLOCKS
NEW FRONT AND REAR DRIVE SHAFT U-JOINTS
INSTALLED REAR 5 LINK
MOVED REAR AFT 1”
FLIPPED & SWITCHED UPPER CONTROL ARMS
NEW U/L BALL JOINTS & OUTER TIE RODS
SWAPPED IN RADFLO COIL OVERS
INSTALLED NEW O2 SENSORS
NEW FUEL FILTER
NEW THERMOSTAT
NEW WATER PUMP
NEW CAMSHAFT ACTUATOR SOLENOID
CLEANED THROTTLE BODY
NEW SPARK PLUGS & AIR FILTER
INSTALLED 3” BODY LIFT
SWAPPED 4WD TCCM
REPLACED LEFT REAR PASSENGER WINDOW POWER REGULATOR
INSTALLED NEW HELLA LIGHTS ON FRONT BUMPER
NEW POWER STOP BRAKES ROTORS AND PADS ALL 4 CORNERS
Aries
by Aries » Tue Mar 01, 2016 4:27 pm
Suspension Modifications:
  • Flipped UCA
  • Radflo Custom Coilovers, Front
  • Moog Upper/Lower Ball joints
  • Z71 Rear Springs
  • BDS 55619 Shocks, Rear
  • 1.5" wheel spacers
Exterior Modifications:
  • Resonator Delete
  • Redline Hood Lift Struts
  • Mark Mc 3"Body lift
  • Hitch Spare Tire Carrier
  • Hella Lights on Front Bumper
  • Custom front bumper
Drive-train Modifications:
  • New/Rebuilt Trans in 09 (Purchased On-line)
  • Transmission Cooler
  • GM 8.6 Rear and Front 7.2 Re-geared 4.56
  • Rear Powertrax No-Slip 92-07863005
Interior Modifications:
Electrical Mods
  • DieHard Platinum Size 35 Battery
  • ScanGaugeII w/X-Gauge™
Recovery & Emergency Equipment:
  • I-Phone
Aries
Return to Mall Rated Builds
