2005 Chevrolet Trailblazer EXT LT V8
DRIVETRAIN SPECS:
5.3L V8 (Bored .020 over), 4WD, 4.56 Gears, Detroit Locker
TIRES:
LT285/70R17 Mastercraft Courser MXT Load E Mud Tires
MB Wheels TKO - 17X8.5 6-5.5" 25mm offset
Matching Full Size Spare Tire/Wheel
MarkMC's 1.5” 6-5.5" Wheel Adapters
SUSPENSION:
~4.5" of Suspension Lift
FRONT
Radflo Coil-overs
MarkMC Top Spacers
Upper Control Arms (Flip/Reversed)
REAR
MarkMC's 2.5” Rear Kit
Moog Tahoe Z71 Rear Coils
Bilstein HD Rear Shocks
Rear Sway Bar Delete
ErikSS's Panhard Bar Drop Braket
Spohn Adjustable Panhard Bar
ENGINE MODIFICATIONS:
BLOCK
LH6 Gen IV 5.3L V8 Bored 0.020" Over
Line Honed Mains
Crank Grind and Polish
Block Resurfacing
Speed-Pro Hypereutectic Flat Top Pistons
Eagle Specialty Products Forged 4340 Steel Connecting Rods
Full Rotating Assembly Balance
Texas Speed Stage 2 Truck Cam - 212/218, .550"/.550", 114 LSA
Texas Speed Chromoly Pushrods
LS7 Lifters (AFM/DOD Delete)
LS2 Lifter Trays
LS7 Valley Cover (LOMA Delete)
LS2 Timing Set and Damper
Tick Performance Blueprinted & Ported Oil Pump
HEADS
3-Angle Valve Job with New Valves
Head Resurfacing
LS6 Behive Valve Springs
EXHAUST
Magnaflow Turbo Muffler
Magnaflow High Flow Cat's
Resonator Delete
DRIVETRAIN MODIFICATIONS:
Built-up 4L60-E Transmission
B&M 70268 SuperCooler Trans Cooler
4.56 Gears by Motive Gear
Eaton Detroit Locker in the Rear
AWD Sleeve in Front Disconnect
4.2L Higher Stall Torque Converter
EXTERIOR MODIFICATIONS:
MDB Fabrication Front Bumper and Brush Guard Kit
MDB Fabrication Radiator Skid Plate
MDB Fabrication Oil Pan Skid Plate
KAWELL 42W 4.6" 60 Degree Round LED Lights
TMH 20" Dual Row Combo High Power 126w LED Light Bar
Aftermarket Black Front Grille and Bar
Aftermarket Aluminum Bow Tie (painted red)
Blue Ox Front Base Plate
Removed chrome lettering
Painted rear bowtie black
Black V8 Emblems
Roof Rack
FireStik Adjustable Stainless Steel Door Jamb Antenna Mount
Firestik Stainless Steel Heavy Duty CB Radio Antenna Mount Spring
Firestik 3' 650W Tunable Tip CB Antenna
INTERIOR MODIFICATIONS:
Trailblazer SS Gauge Cluster
JVC DD Stereo - Bluetooth, SiriusXM, works with factory steering wheel controls and Bose Audio
Uniden CB Radio
ELECTRICAL MODIFICATIONS:
All LED Exterior Lighting
Quad Headlight Mod
DRL Capacitor Mod
Optima Yellow Top D34/78 Dual Post Battery
400W Power Inverter
Front and Rear Quick Disconnect Winch Wiring
RECOVERY EQUIPMENT:
Badland 12000 Lb. Off-Road Vehicle Electric Winch With Automatic Load-Holding Brake
Hitch Receiver Mount Winch Plate
20000 Lb. Snatch Block
FUTURE MODIFICATIONS:
Only needed a new tensioner.
