Ring/Pinion Gear Brands
by HARDTRAILZ » Fri Dec 30, 2016 1:49 pm
6-10 is front and rear recommended by GM and most aftermarket gears say 6-12.
Pinion Preload(New) Pinion Preload(Reused) Ring Gear Backlash Ring Gear Bolt Torque Carrier Bearing Cap Bolts
GM 7.2" IFS 11 to 14 in-lbs. 6 to 7 in-lbs. .006" to .010" 65 ft-lbs. 60 ft-lbs.
GM 8.5" / 8.6" 14 to 19 in-lbs. 6 to 8 in-lbs. .006" to .010" 65 ft-lbs. 60 ft-lbs.
by Anthony Hernandez » Fri Dec 30, 2016 7:26 pm
James said to check my tire pressure that the no slip is a clunky whore if they are off ( not his words btw )
by HARDTRAILZ » Fri Dec 30, 2016 7:30 pm
That's a whole different issue than gears. That kinda locker is a bit sloppy.
by Timberwolf » Sat Dec 31, 2016 9:20 am
HawkeyeC25 wrote:I supplied the gears, locker, and rebuild kit including bearings and seals for both front and rear diffs. The prices are for labor with me just dropping off all the parts and axles still assembled.
Did you need a different carrier for the front? It's been a while since I've had gears done. Seems like I remember you needed a different carrier for the numerically higher ratios.
I guess same question for the rear, though I know you made that moot in your case by supplying a detroit locker carrier.
Any chance you still have links to where you bought everything?
Timberwolf
by HARDTRAILZ » Sat Dec 31, 2016 5:14 pm
There are no carrier cutoffs on our diffs.
by HawkeyeC25 » Sun Jan 01, 2017 1:12 am
Nope, I used the stock carrier for the front. And you can for the rear, but as a reminder, I have the EXT 8.6" rear end and Eaton doesn't make a Detroit Locker for the 8". They do make a Detroit TrueTrac for the 8".
I bought the gears and rebuild kits as a package... but i'm sure you can search and find the rebuild kits by themselves.
https://www.amazon.com/gp/product/B01M0 ... UTF8&psc=1
https://www.amazon.com/gp/product/B01LX ... UTF8&psc=1
https://www.summitracing.com/parts/dtl-187c148a
HawkeyeC25
by Timberwolf » Wed Jan 25, 2017 1:34 pm
Bought the stuff you linked (other than I went with a trutrac in the back) and an 8.6 rear. Dropped everything off to DTS in Ionia. He just called to say the bearing kit for the front was incorrect. He's ordering the right one. No big deal, just wanted to throw a heads up in case someone else uses these links to do what I'm doing (and you did). He quoted his labor at $625, plus he has to get the needle bearings for the IFS diff at $15-$30 each (he wasn't 100% sure on price)
Timberwolf
by Lone_Wolf » Mon Oct 01, 2018 11:34 am
How much should I expect to pay for 4.10 ring and pinion. My dad and I can do all the labor ourselves so just need a rough price quote. I just want to run 32 or 33s on my TB.
Lone_Wolf
by cpyonker » Mon Oct 01, 2018 3:25 pm
You know you need to rehear front and rear right?
cpyonker
by mason10198 » Mon Oct 01, 2018 3:32 pm
Lone_Wolf wrote:How much should I expect to pay for 4.10 ring and pinion. My dad and I can do all the labor ourselves so just need a rough price quote. I just want to run 32 or 33s on my TB.
I bought mine from Yukon Gear & Axle on Amazon. You'll need a gear set and an overhaul kit for each diff. Here's what I paid:
Front Diff
    4.56 Gearset - $126
    Master Overhaul Kit - $122
Rear Diff
    4.56 Gearset - $231
    Master Overhaul Kit - $175
    Eaton E-Locker - $780
Total - $1434 // ($654 w/o E-Locker)
