Ring/Pinion Gear Brands
by mason10198 » Mon Jun 13, 2016 11:12 pm
Hey everyone, although it will still probably be a while, I'm starting to look further into my regear & rear axle swap. I have found 4.56 gear kits from Yukon gear and axle over at summit racing for around $250, and then I've found cheaper options such as a brand name of Motive Gear, and the MUCH cheaper options like the one in this link. http://www.ebay.com/itm/CHEVY-GM-8-6-10-Bolt-Gears-Ring-Pinion-4-56-NEW-/391417549610?_trksid=p2141725.m3641.l6368
I know practically nothing when it comes down to metal strengths and the different strength treatments/quality. The cheapest gearset (in the ebay link above) says "Manufactured with 8620 Heat-Treated Material" and "Premium Quality Gears" all over it. But I don't know what "8620 material" means in this context, and of course its ebay....
When I think of anything driveline/powertrain, I automatically assume the most expensive is the best quality and best option. Is there a massive difference between these gears that I should spend the extra 150+ bucks on? Or would I be just a good off getting a set from Motive gear or possibly even an Ebay seller?
Thoughts and opinions please. Thanks!
by Jrgunn5150 » Tue Jun 14, 2016 7:18 pm
I'm not familiar with the Ebay set, but Motive is a good quality brand, I've used several of their gear set's without an issue.
by v7guy » Tue Jun 14, 2016 9:57 pm
I've used Yukon a number of times. If you search enough online there's shit talk about all the major brands... they've pretty much all had an issue at some point or another. Haven't heard anything negative about the major brands in quite awhile though.
by mason10198 » Thu Jun 23, 2016 10:56 am
I can't freaking decide on 4.10s or 4.56s.. I really just want to grab the 4.10 front and an open rear from a pull-a-part and pop those in instead of having to deal all the crap that comes with an actual gear swap.
Sent from Tapatalk
by Aries » Thu Jun 23, 2016 11:37 am
mason10198 wrote: I really just want to grab the 4.10 front and an open rear from a pull-a-part and pop those in instead of having to deal all the crap that comes with an actual gear swap.
Looks like you made up your mind.
Aries
by mason10198 » Thu Jun 23, 2016 12:43 pm
Guess you're right. Now to see if that changes again next week
Sent from Tapatalk
by escapepilot » Thu Jun 23, 2016 3:30 pm
4.10s will probably cause you less headaches - viewtopic.php?f=11&t=5369
But I like my 4.56s!
escapepilot
by mason10198 » Thu Jun 23, 2016 4:10 pm
escapepilot wrote:4.10s will probably cause you less headaches - viewtopic.php?f=11&t=5369
Been reading that too. Definitely want to do whatever I can to make ABS happy... I hate messing with thag crap. Also going up north of the state this weekend and just found an open 4.10 8.6" up there, might come home with it.
Sent from Tapatalk
by HawkeyeC25 » Sat Nov 12, 2016 6:52 pm
So did you ever pull the trigger mason?? I'm thinking of doing 4.56 gears now that I have the front diff sitting on the floor :) I'm trying to figure out who to go with.
HawkeyeC25
by mason10198 » Sat Nov 12, 2016 7:01 pm
HawkeyeC25 wrote:So did you ever pull the trigger mason?? I'm thinking of doing 4.56 gears now that I have the front diff sitting on the floor :) I'm trying to figure out who to go with.
Unfortunately not! I haven't made it that far yet. But I definitely plan on it in the future!
Sent from my SAMSUNG-SM-G870A using Tapatalk
by larryk » Sat Nov 12, 2016 11:19 pm
If anyone wants an open 8.6 from my ext....come and get it. If I don't get a taker in the next two weeks, I'm dumping it in a river just to see how big the splash is
larryk
by ErikSS » Sat Nov 12, 2016 11:35 pm
Larry, a location would help people know if they want it! Gear ratio?
by larryk » Sun Nov 13, 2016 7:12 am
Suburb of Chicago.... Willing to drive to meet up if need be, as I'd rather see this perfectly fine axle go to a good home. It's currently 3.42..... There had to be someone with a SWB that could use a better axle?
larryk
by mason10198 » Sun Nov 13, 2016 11:14 am
That's exactly what I'm going to need later for my swap/gear change unless I decide to go the SS route instead, but I'm way down here in central Arkansas...
by larryk » Sun Nov 13, 2016 2:46 pm
I did mention....free, right?
larryk
by mason10198 » Sun Nov 13, 2016 4:36 pm
How far are you willing to drive?
by ErikSS » Sun Nov 13, 2016 8:04 pm
Larry, I could probably snag that and hold onto it for someone. Which Suburb? Perhaps PM me. I'm in Lansing, also a Chicago burb.
by HawkeyeC25 » Sun Nov 13, 2016 11:24 pm
I hope you can get a hold of the axle Mason!
Here's my plan for now... about to pull the trigger on the order :)
HawkeyeC25
by mason10198 » Sun Nov 13, 2016 11:26 pm
HawkeyeC25 wrote:I hope you can get a hold of the axle Mason!
Sweet man!! Are you going to set them up yourself or take it to a shop?
by HawkeyeC25 » Mon Nov 14, 2016 12:09 am
Haven't decided yet - probably comes down to how much someone will charge me vs how much I want to learn how to do it :mechanic:
HawkeyeC25
