Drive shaft length or motor mounts
by anthonyl79 » Sun Apr 10, 2016 6:01 pm
At my wits end here, swapping a 5.3 into a 4.2 envoy that is 4x4. Got factory mounts and mount brackets but the transmission cross-member doesn't line up. So do I have 2x4 mounts and its pulled the motor forward or is it sitting in the right spot. Cant find numbers on the mounts or was trying to see if the drive shaft is a different length. That could tell me, but NO one seems to have the rear shaft. So does anyone know the stock length on the rear shaft from a 2x4 and 4x4?
Thanks!
anthonyl79
by v7guy » Mon Apr 11, 2016 1:34 am
You have the stock I6 trans mount you're trying to use?
If I remember correctly the shorter V8 moves everything forward a few inches, consequently everything moves forward too
by anthonyl79 » Mon Apr 11, 2016 2:42 pm
That's what I've noticed. According to GM the crossmember is the same, mounting location to the frame moved forward on the V8.
Does anyone out there know the length on the V8 driveshaft by chance?
anthonyl79
by Jrgunn5150 » Mon Apr 11, 2016 6:03 pm
anthonyl79 wrote:That's what I've noticed. According to GM the crossmember is the same, mounting location to the frame moved forward on the V8.
I'll measure for you when I get home tonight.
Usually, GM keeps the bellhousing location the same, everything moves forward or backward from that zero location.
by anthonyl79 » Mon Apr 11, 2016 10:44 pm
Thanks!
anthonyl79
by v7guy » Mon Apr 11, 2016 11:11 pm
I do know the front driveshafts have different part numbers, one can assume the length is the difference since the front diff and trans case is the same. The front diff needs to be in the same location by virtue of it needing to line up with the suspension
http://www.ebay.com/itm/06-07-08-09-TRA ... 0765620361
Per that eBay ad the front driveshaft is the same on the 5.3 and 6.0 trucks and is 34.25 inches.
You could double verify it by comparing that to your I6 driveshaft I believe.
Plus you'll have a measurement here in a bit from a v8 truck LOL
by Jrgunn5150 » Mon Apr 11, 2016 11:16 pm
Wait, which shaft do I need to measure? Lol.
by v7guy » Mon Apr 11, 2016 11:47 pm
I think he wants the one in your pants!
Or the rear one...
That just got weird
by anthonyl79 » Tue Apr 12, 2016 12:36 am
:lol: :mrgreen: looking for the rear one.
anthonyl79
by Jrgunn5150 » Tue Apr 12, 2016 12:40 am
Lol, ok I'm home now one minute.
by Jrgunn5150 » Tue Apr 12, 2016 12:45 am
Near as I can tell in the dark in my driveway, center of the u joint to center of the Ujoint is 38.5"
by anthonyl79 » Tue Apr 12, 2016 2:32 am
Well that's good then. Mine is 36, so what year and all that you have?
anthonyl79
by Jrgunn5150 » Tue Apr 12, 2016 2:37 am
Mine is an 07, Swb, 4X4, 5.3
by v7guy » Tue Apr 12, 2016 3:42 am
Tony, you got any more details on this process? Any place you've been documenting it at? For example what all you've had to change, adapt, etc?
I haven't done a swap like this on the new canbus vehicles, I'm interested in seeing what all you've come up with/against... as I'm sure others are too.
by anthonyl79 » Tue Apr 12, 2016 9:01 am
I'm working on all that stuff, I'll post when completed. I did start a build threado a whole back
anthonyl79
by Jrgunn5150 » Tue Apr 12, 2016 5:59 pm
Yeah i haven't actually seen a comprehensive thread on a swap.
I've seen a few people turn their TB's into part's trucks though lol.
by anthonyl79 » Tue Apr 12, 2016 8:26 pm
Well thanks to Jrgunn I have found the correct shaft. The local junk yard has one. The stock i6 measures 36" center of joint to center of joint. From what you told me yours is 38.5" center of joint to center of joint. Measuring the placement of the transmission mount on the transmission cross member it moved 2.5". So fabricated a new cross member from the old one and its all mounted up. I need to get some pictures but I'll do that when I pull it to paint it.
Thansk again Jrgunn for answering the question that I couldn't find anywhere.
anthonyl79
by Jrgunn5150 » Tue Apr 12, 2016 8:30 pm
anthonyl79 wrote:Thansk again Jrgunn for answering the question that I couldn't find anywhere.
No problem! I actually helped myself as well lol, now I know I can just go buy an I6 driveshaft when I put my 14 bolt in lmao.
