by ErikSS » Sun Aug 23, 2015 9:47 pm
I find it depends partially on what you intend to use the truck for. I have the 14 bolt with the factory limited slip. I love it on and off road. If I were to do a ton of deep mud or rock climbing, a locker would suite me better. I don't. It's not worth it for me to change at this point. You do have to shorten your drive shaft and get a special U joint... Otherwise it's not typically a major swap. You have an 03, they didn't start using the 14 bolt until the 2006 SS. It seems they had different wheel speed sensor and different brake lines. I think you can easily put the newer axle in the older truck, but not the older axle in the newer truck.
