Shdwdrgn wrote:@Trail X -- I'm surprised you even got 18 with 32/3.42. That combination has to put a huge load on the drivetrain. Last time I actually took a road trip I think I got around 19 with my 30.6/4.10. I so rarely burn through a tank of gas on the highway that its hard to get a reading. However for my typical driving to work and around town I'm typically in the low 16's in the Summer and mid-15's in the Winter.
[Edit] I just checked the numbers, you're only running about 60rpm higher than me at the 65mph mark, so I wonder what else is eating into your mileage? I know I saw a hit going to M+S tires and I bet yours are more aggressive, but still?
It did put a large load on the engine at that RPM, but that is why it gave good fuel mileage. IC engines perform more efficiently when run with minimal intake vacuum (ie, wide open throttle). I had a good system for minimizing intake vacuum by watching the scangauge intake pressure reading. The intake has around a 0.9 psi pressure drop, so for me, the ambient pressure is 14.9ish, so if I can set the throttle to achieve 14.0psi, I'm running at essentially peak efficiency. Since I am now running a higher rpm at speed, where I'm creating more power, if I set my throttle to 14.0psi, I would go too fast. So therefore my efficiency took a big hit (unless I want to accellerate and then coast, accelerate then coast, etc).
Plus, yeah, I think these tires don't help anything. Their rolling resistance seems awful.
