To add limited slip additive or not ??
by Chango » Thu Jul 17, 2014 8:12 pm
Bought some 75w-90 rear diff oil for my G86. It says it has the additive in it. I have been reading on the SS boards they put additive in with the gear oil. Should I double dip and add additive in with the oil even though it says it has it already??
Chango
by Bacnbit » Fri Jul 18, 2014 2:38 pm
Chango wrote: Should I double dip and add additive in with the oil even though it says it has it already??
Double dip for sure. I know some guys use Royal Purples version but we had a failure after servicing which we all know could be just the nature of the beast. But We always added even when containers stated Friction Modifier Included. After That. 8 bucks or 250+? Just my opinion.
Bacnbit
by DustinC1989 » Fri Jul 18, 2014 2:59 pm
Could run Dexron LS 75-90, that certainly doesn't need any additive
DustinC1989
by Bacnbit » Fri Jul 18, 2014 3:05 pm
DustinC1989 wrote:Could run Dexron LS 75-90, that certainly doesn't need any additive
:Iagree:
Bacnbit
by The Roadie » Fri Jul 18, 2014 3:31 pm
The SS limited slip is different than our G80 locker. I use Mobil 1 that has the LS additive in it already, and it can't cause harm. But paying money to add more when the utility isn't there for the G80? No purpose.
by Chango » Fri Jul 18, 2014 4:24 pm
The Roadie wrote:The SS limited slip is different than our G80 locker. I use Mobil 1 that has the LS additive in it already, and it can't cause harm. But paying money to add more when the utility isn't there for the G80? No purpose.
I guess I should have put that I am talking about the SS rear.
Chango
by navigator » Fri Jul 18, 2014 4:28 pm
I have the Saab 8.6 with the G86 in my TB.
I just used the Mobile1 with the LS additive and it sounds fine, nothing out of the ordinary.
I might have only 100 miles or so on it though.
by The Roadie » Fri Jul 18, 2014 4:53 pm
Chango wrote:I guess I should have put that I am talking about the SS rear.
So many members doing so many projects....declining number of brain cells to process them..... :facepalm:
If you're putting in the SS axle, you should also be changing out the LS to a locker while you're in there. At least I would be. :safari:
by Chango » Fri Jul 18, 2014 8:29 pm
I am putting in the SS axle...ls will have to work for now. Moneys tight, will use that locker money to rebuild the front diff I got with bad bearings.
Chango
by DustinC1989 » Fri Jul 18, 2014 10:43 pm
The Dexron LS is the factory fill for the SS axle, or just add extra friction modifier. Personally, I'm not a fan of additives and tend to stick with factory fill on special applications like that
DustinC1989
