2wd rear end swap question.
by ktrain evnoy » Tue Mar 26, 2013 11:20 am
I have a 04 envoy sle I6. I work for a shop and can get a deal on a rear axel out of an 02 envoy with 4.10 with g80. I want to do the swap so i have power to both wheels when i am off pavement. Nothing crazy. Is it worth it? I heard there could be issues putting and older axel in a newer vehicle.
ktrain evnoy
by HARDTRAILZ » Tue Mar 26, 2013 11:21 am
You are fine. The transition is 06.
The only issue you will have is the speedo being off a bit.
by boog2006 » Tue Mar 26, 2013 11:25 am
ktrain evnoy wrote:I have a 04 envoy sle I6. I work for a shop and can get a deal on a rear axel out of an 02 envoy with 4.10 with g80. I want to do the swap so i have power to both wheels when i am off pavement. Nothing crazy. Is it worth it? I heard there could be issues putting and older axel in a newer vehicle.
Where'd you find the 4.10 G80? I'm not having much luck
Boog2006 Build Thread
boog2006
by ktrain evnoy » Tue Mar 26, 2013 11:28 am
Car-part.com Its used w/ 6month warranty
ktrain evnoy
by ktrain evnoy » Tue Mar 26, 2013 11:31 am
boog, I looked and i show some in your area. As long as you still live where it says in your info.
ktrain evnoy
by Gordinho80 » Tue Mar 26, 2013 11:43 am
Is your front 4.10 as well?
by HARDTRAILZ » Tue Mar 26, 2013 11:49 am
Gordinho80 wrote:Is your front 4.10 as well?
It is 0.00 as in...non-existant.
by boog2006 » Tue Mar 26, 2013 11:59 am
ktrain evnoy wrote:boog, I looked and i show some in your area. As long as you still live where it says in your info.
shoot me your information. I'm still here. Everything I've found is Ohio, Michigan, or Wyoming if i recall right.
boog2006
by boog2006 » Tue Mar 26, 2013 12:03 pm
I feel like an idiot. I can't effectively search carpart...all I'm getting is options for the front cv axle.
Sorry :hijack:
boog2006
by Gordinho80 » Tue Mar 26, 2013 2:18 pm
Oh crap.. didn't realize... :wallbash:
by DustinC1989 » Tue Mar 26, 2013 2:43 pm
Sorry :hijack:
Scroll all the way down to rear axle assembly (rwd)
DustinC1989
by Cable810 » Tue Mar 26, 2013 3:15 pm
6 month warrenty... wow I got a 90day on mine. But I ain't worried its only got 13K on it :D
by navigator » Tue Mar 26, 2013 4:04 pm
Sorry :hijack:
I always searched for "Axle Assy Rear (w. Housing)
Looks like the same parts.
by boog2006 » Tue Mar 26, 2013 4:19 pm
Thanks...turns out carpart.com is not car-part.com
If I open up to 2002 stuff I have some options.
boog2006
by navigator » Wed Mar 27, 2013 1:56 pm
boog2006 wrote:....
but you lose stabilitrack, ABS and have an annoying ABS light on.
by boog2006 » Wed Mar 27, 2013 2:28 pm
Decisions....what about a used gear setup swapped onto my housing? Would that be worth the trouble?
boog2006
by DirtyBacon04 » Wed Mar 27, 2013 3:51 pm
Only if you're doing the work... I don't think it'd be worth the money for labor to regear.
