Axle Swap Driveshaft?
by Cable810 » Fri Mar 01, 2013 12:19 pm
If this isn't in the right spot mods please move to appropriate spot. On to my question. I've been doing some reading in the chiltons manual on different things regaurding my upcoming axle swap. I was going through on how to remove the driveshaft and it said to make a reference mark on where the shaft attaches to the pinion flange. Well with swaping out the rear axle I will not have the mark on the flang. So how am I to know what is the right way to reconnect the driveshaft? Make sense?
by The Roadie » Fri Mar 01, 2013 12:29 pm
I just winged it. One way *might* have a bit less vibration after an axle swap, but offroading junk tends to vibrate on a good day, so I would not sweat it.
by HARDTRAILZ » Fri Mar 01, 2013 12:54 pm
You will never know where it would have been aigned, however I have never had an issue in the dozens of rearends I have swapped in vehicles over the years.
by v7guy » Fri Mar 01, 2013 1:06 pm
I've had the same experiences as Kyle, at worst I've rotated the drive shaft 180 to eliminate vibrations.
by fishsticks » Fri Mar 01, 2013 1:31 pm
+1...
Since there's no slip joint in the middle of our driveshafts (it's at the back of the t-case instead) it's really not an issue.
by Cable810 » Fri Mar 01, 2013 2:48 pm
Awsome! Thanks Guys!!
by Sugar16 » Fri Mar 01, 2013 5:35 pm
As long as your driveshaft is phased correctly it won't make a difference when you connect the flanges
Sugar16
by chevycrew » Fri Mar 01, 2013 7:58 pm
Yep, it don't matter, not sure why they even mention it.
by HARDTRAILZ » Sat Mar 02, 2013 3:13 am
Tequila
by v7guy » Sat Mar 02, 2013 9:22 am
whiskey
by Cable810 » Sat Mar 02, 2013 9:38 am
Rye Wiskey haha!?!?!?
by v7guy » Sat Mar 02, 2013 1:56 pm
Cable810 wrote:Rye Wiskey haha!?!?!?
c'mon now, you're worth at least some Wathens bourbon aren't you? I know Kyle is.
by Cable810 » Sat Mar 02, 2013 7:34 pm
It was the first thing that came to my mind haha. I don't even know what Wathens bourbon is Kinda got off topic....
by HARDTRAILZ » Sat Mar 02, 2013 9:45 pm
Crown tonight
by fishsticks » Sat Mar 02, 2013 9:50 pm
HARDTRAILZ wrote:Crown tonight
Crown every night.
by v7guy » Sun Mar 03, 2013 3:44 am
I don't even call it a hangover anymore, it's just "waking up" :friday:
