Starting a straight axle swap
by pearl4x4 » Fri Feb 15, 2013 12:24 pm
Im new so I will give you all the low down on the task at hand. Would appreciate any ideas or issues foreseen by some tb owners.
-going back to old school chevy side front diff
-dana 60 and 14bolt 5.38 gears spools front and rear
-hydro steering
-1/2 ton chevy springs (Thanks To Chevycrew)
-Dana 300 case and adpters to 4l60e
pearl4x4
by TSAdventurez » Fri Feb 15, 2013 12:26 pm
Good luck with the build. Cant wait to see pictures and welcome to the forum!
:mechanic:
TSAdventurez
by bartonmd » Fri Feb 15, 2013 12:44 pm
Cool! I'm interested in what you come up with!
by Trail X » Fri Feb 15, 2013 2:29 pm
Interesting... this will make trailer queen #2!
by chevycrew » Fri Feb 15, 2013 4:19 pm
Exhaust is on the passenger side, lots of lift needed to clear a more centered chevy diff under the oil pan, low pinion, short front driveshaft with 300, etc, etc. Plan well, build once.
by Nakashige » Fri Feb 15, 2013 9:58 pm
That's going to be alot more lift then even I have and I have tons on mine.
Nakashige
Vendor
by v7guy » Fri Feb 15, 2013 11:11 pm
Rear sump oil pan?
by HARDTRAILZ » Sat Feb 16, 2013 12:50 am
Nice
by chevycrew » Sat Feb 16, 2013 2:16 am
Rear sump pan, that's my next fab project...
by pearl4x4 » Sun Feb 17, 2013 10:47 pm
easy guys Im taking the exhaust from the manifold straight 90 out the inner fender well and down the outside of the frame. And thanks chevycrew Im going with the 52" chevy springs also
pearl4x4
by pearl4x4 » Sun Feb 17, 2013 10:56 pm
Ive been thinking I have to build my own oil pan. has anyone found a rear sump?
pearl4x4
by pearl4x4 » Sun Feb 17, 2013 11:02 pm
And FYI no trailer queen.
pearl4x4
by chevycrew » Mon Feb 18, 2013 12:58 am
If you run the exhaust outside the frame your passenger front tire will rub on the exhaust when turning to the right.
Yes rear sumps are available, last I heard, neighborhood of $600.
52" springs will work well, just have to build your lift into the hangers, depending on the tire size you want to run.
by pearl4x4 » Mon Feb 18, 2013 7:28 pm
yeah the exhaust thing is really becoming a headache
pearl4x4
by pearl4x4 » Mon Feb 18, 2013 7:30 pm
anyone know were to get the pickup for going to a rear sump?
pearl4x4
by chevycrew » Mon Feb 18, 2013 7:40 pm
Exhaust: Thats why the 3 of us here that have SAS are all drivers drop...
Pickup: Make it.
by chevycrew » Mon Feb 18, 2013 7:42 pm
Also on the pan, I will find out what the flange cost will be let you know. Since it will already be programmed in to cut.
by Nakashige » Wed Feb 20, 2013 2:30 am
I have a very limited exhaust its great to be on a trailer where are you located that you are going to get this to pass inspection?
Nakashige
Vendor
by v7guy » Wed Feb 20, 2013 3:40 am
Pics or it isn't happening.
by Nakashige » Wed Feb 20, 2013 10:48 am
I want to see some axles. We all doubted steve then there were photos
Nakashige
Vendor
