want to order gears
by MK-voy » Tue Jul 24, 2012 1:35 pm
i have found 4.56 gear ratio for the front diff but not for my rear 8.0 diff i need to swap for the 8.6 to get them??
MK-voy
by 06MidnightBlue » Tue Jul 24, 2012 4:23 pm
Not necessarily. I've been told that Yukon Gears can custom cut them for the 8.0. You just gotta have the bank to do it.
06MidnightBlue
by DirtyBacon04 » Tue Jul 24, 2012 4:40 pm
Cheaper to get an 8.6" from a junkyard w/o a g80. Put 4.56 and a LR in there. Thats my long term plan.
by navigator » Tue Jul 24, 2012 9:52 pm
you could also just go with 4.10 front and rear.
It just depends on what your long term goals are.
by 06MidnightBlue » Tue Jul 24, 2012 10:16 pm
I'm planning on 4.10's for my 8.0
06MidnightBlue
by fishsticks » Wed Jul 25, 2012 1:56 am
DirtyBacon04 wrote:Cheaper to get an 8.6" from a junkyard w/o a g80. Put 4.56 and a LR in there. Thats my long term plan.
This.
by navigator » Wed Jul 25, 2012 8:12 am
I wonder if the 8.6 rear is as easy to score in Lebanon as here in the US?
by fishsticks » Wed Jul 25, 2012 12:22 pm
navigator wrote:I wonder if the 8.6 rear is as easy to score in Lebanon as here in the US?
In a pinch he could source one from a half ton truck and have his perches and tabs welded onto it.
by bartonmd » Wed Jul 25, 2012 1:40 pm
That actually might work well. No need for spacers in the rear, because it's already about 4" wider...
by navigator » Wed Jul 25, 2012 1:51 pm
hmmm
then you should just need 2 inch spacers in the front to be evenly spaced.
I expect the ones on the 1/2 tons are easier to source than from a TB.
Do they have the same break downs as far as ABS etc? I mean for like my 06 would I need an 05+ or are the break downs different? Is there any difference in driveshaft lengths?
I expect we would also have to weld on new shock mounts also but that shouldn't be a huge deal.
by fishsticks » Wed Jul 25, 2012 2:12 pm
navigator wrote:hmmm
The front track on a stock TB is actually 1" wider than the rear. 1.5" would make it "even". 2" would keep the extra 1" width.
I only bring it up since 1.5" spacers/adapters are commonly available in our pattern.
by navigator » Wed Jul 25, 2012 3:32 pm
Nice!
