Rear Axle Upgrade - choosing the right locker
by Karo » Sun May 27, 2012 3:11 pm
Upgrading the rear axle was in my mind long ago. My 8.0 rear axle has not failed so far, but if it would - it would be a big problem to receive parts in time here in germany. So i have searched online for a while to get a good price incl. shipping to germany. After receiving the 8.6 rear axle from the U.S. i would like to upgrade the locker from the axle too.
Two choices are possible for me as i would like to manually activate the locker:
1. GM 8.5" / 8.6" ARB Air Locker RD84 | 30 Spline
2. Eaton Locker
Which one would you recommend to choose and why? Please keep in mind that OBA is already available.
Need your input guys..
Thanks
KaRo
Karo
by NC_IslandRunner » Sun May 27, 2012 5:00 pm
I know the ARB air lockers are said to be good.
Which Eaton locker, They make several? including our G80.
by The Roadie » Sun May 27, 2012 5:17 pm
I think Teebes and AlekG got the Eaton E-lockers.
by NC_IslandRunner » Sun May 27, 2012 5:26 pm
The Roadie wrote:I think Teebes and AlekG got the Eaton E-lockers.
Not the easiest guys to get an opinion from anymore...Try searching old post about lockers.
by Nakashige » Sun May 27, 2012 6:27 pm
I have only heard good things about eaton e lockers. Ordered front and rear for the sas
Nakashige
Vendor
by Karo » Mon May 28, 2012 5:28 am
Thank´s to all of you!
Found this thread here:http://forums.offroadtb.com/viewtopic.php?f=11&t=2216&start=20
That was really interesting. The auburn seems to be an option, but after reading on pirate4x4 ithink i´ll have to read more..
Found this thread from teebes: http://forums.offroadtb.com/viewtopic.php?f=11&t=1270&start=20
AlekG is using the auburn ected too.. Have to read more, the main problem on arb´s are air leaks and compressor problems from which i have read so far.
As i have 2 compressors installed that would only be a problem to have solenoids as spares and some more little things.
From the point of view now the auburn ected could be a good choice, but there is maintenance to the locker needed as it has clutches. Both lockers need maintenance regardless if it is a clutch failure or a leaking air problem.. Hm difficult to decide..
KaRo
Karo
by fishsticks » Wed May 30, 2012 12:59 am
Given those choices, I'd go ARB.
Install a small air tank (if you haven't already) so you can engage the locker even if your air compressor dies. People have used a CO2 tank to engage their ARBs in a pinch.
They can all fail (we had an ARB in our group quit working over the weekend), but in wet/muddy/dirty environments I'd much rather rely on air than electricity.
by Trail X » Wed May 30, 2012 1:14 pm
fishsticks wrote:Given those choices, I'd go ARB.
I'm not sure if Alek's E-locker is still operating. His electrical leads got ripped off due to a failure of the stationary electrical transmitting element (for lack of a better term) in the locker. Seems the element that was supposed to be stationary began spinning with the diff housing and ripped the wires off.
Not saying it's a common failure, but apparently it happens.
The more I've looked into it, the more I'm liking the powertrax rear diffs. Though I have no idea what I'd chose if I were going to upgrade tomorrow. I like the idea of selectable too.
by fishsticks » Wed May 30, 2012 2:55 pm
I'm really happy with my Powertrax lockers. The only change I would make is to maybe use an ARB in the front. Sharp turns with a front locker engaged suck. I believe all of my CV breakages were while turning. Since a twin-stick xfer case isn't really an option for us, a selectable front would be nice.
Too bad one doesn't exist for the 7.25".
by HARDTRAILZ » Wed May 30, 2012 3:15 pm
My lockright does good but is noisy.
by Karo » Thu May 31, 2012 2:13 pm
@James My main wish is that the locker is switchable. Never heard of that problem from AlekG, but after hearing that from you it is a no go..
ARB was my first choice and so i'll take that way.
@ Fish & Kyle I dont think i' ll take my TB ever that hard like you guys do, but i love looking at those pictures and videos from you guys! So no one knows if some day i'll drive my TB in the Fish & Kyle Style :-)
Karo
