Differential and Transfer Case Vent/Breather Relocation
by Zero » Mon Apr 25, 2011 10:38 pm
If I may, I'd recommend not putting your breathers there. Mainly cause there is a large gap between the hood and the body....water may run down and soak your filters when the vehicle is parked, maybe even while driving through heavy rain. It might be something for you to keep an eye on.
by fishsticks » Mon Apr 25, 2011 11:21 pm
Like. Will probably steal/duplicate. That the best flattery I know. :mrgreen:
by Blackout » Tue Apr 26, 2011 12:03 am
Thanks guys, I appreciate it. I noticed that when I put the hood down after I was done Zero, haven't come up with a fix yet. Might just get something to seal it a bit or put a lid over the filters so water runs out over the side of them. Have to think about it. Thanks for the input. Next step is to try and wiggle my fat hand down to get hold of the transmission breather.
Blackout
by SteveTB03 » Tue Apr 26, 2011 9:27 am
I like that bracket idea, very nice! But I think a shield would be fine to keep any water at bay from getting to the filters.
Go Big & Go Broke
SteveTB03
by darring70 » Thu May 30, 2013 1:45 am
I don't know if is me but I can not see the pictures, does anyone have pictures? I want to relocate my breathing vents.
darring70
by v7guy » Thu May 30, 2013 8:28 am
nah, the pictures are gone, just went outside and took these pics for ya. this is what I did with the front and rear diff. then I jammed the stock cap in the tube. the transmission tube is awful high, so I didn't bother with it. if water gets this high I've got a lot of other problems to worry about first.
by TBYODA » Thu May 30, 2013 9:20 am
Just to be clear the first & sec pic is the xfer case tube and the third if the front diff?
by v7guy » Fri May 31, 2013 4:28 am
first and second are rear diff, third is front diff. I thought I put the transfer case by the front diff tube... hmmmm
by darring70 » Fri Jul 26, 2013 6:02 pm
I did my transfer case and my rear differential, but I coud not found my front differential vent / breathing
darring70
by Moots1288 » Fri Jul 26, 2013 6:42 pm
darring70 wrote:I did my transfer case and my rear differential, but I coud not found my front differential vent / breathing
You can get to it through the drivers ice wheel well not to far up from the full plug.
