Blinker flashing fast like bulb is out...but no bulb is out?
by Chango » Tue Jan 26, 2016 1:46 pm
Not on my Tb, but on my work truck. 08 2500 service body, when you turn on either side blinker, it usually blinks slow 3 times then blinks fast like you have a bulb out. But there are no bulbs out.. Sometimes it doesn't do the 3 regular blink, but goes straight to the fast blink.?
Lots of you have waaay more smarts than me on this kind of thing, so I thought Id ask.
Chango
by Rickalicka18 » Tue Jan 26, 2016 1:52 pm
It usually will do that if it feels like a bulb is close to burning out. I'd just replace all the bulbs and see if the problem persists
Rickalicka18
by Chango » Tue Jan 26, 2016 1:56 pm
Should have put that its been this way for the 4 or so years I have been driving it. I have replaced bulbs front and rear in that time.
Chango
by Rickalicka18 » Tue Jan 26, 2016 2:27 pm
Check your blinker relay?
Rickalicka18
by Regulator1175 » Tue Jan 26, 2016 5:24 pm
Are you using LED's bulbs by chance? The hyper flash is an indication of low voltage draw. I have LEDs in my turn signals but have embraced the hyperflash.
by Rickalicka18 » Tue Jan 26, 2016 5:54 pm
Regulator1175 wrote:Are you using LED's bulbs by chance? The hyper flash is an indication of low voltage draw. I have LEDs in my turn signals but have embraced the hyperflash.
Why embrace it when you can put resistors in? Or put an led blinker relay in place of the stock one.
Rickalicka18
by Regulator1175 » Tue Jan 26, 2016 6:01 pm
Ehhh, I like it. Plus, I think the rapid flashing turn signal gets more attention.
by Rickalicka18 » Tue Jan 26, 2016 6:32 pm
Would you still like it if I told you it shortened the life if the bulb?
Rickalicka18
by Chango » Tue Jan 26, 2016 7:44 pm
I will triple check, but I know the fronts aren't. And the rear are the 3" or so circle plastic round replacements with the bulbs already in them. But I'm 99% sure I bought the dino bulbs last time
I'll check the relay, but what am I checking? If it's in one piece or what?
Chango
by Rickalicka18 » Tue Jan 26, 2016 8:00 pm
If its working I guess haha... Its the only other thing I can think of that would be causing your blinkers to hyper flash. I'm thinking its got to be the bulb though..
Rickalicka18
by Regulator1175 » Tue Jan 26, 2016 11:29 pm
Rickalicka18 wrote:Would you still like it if I told you it shortened the life if the bulb?
Bulbs are 5 or 6 years old, I think they are doing ok.
by Jrgunn5150 » Wed Jan 27, 2016 12:15 am
If they pop tomorrow that would be ok with me after 5 year's lol.
by Rickalicka18 » Wed Jan 27, 2016 2:40 am
Touché, as long as they last longer than incandescent bulbs its a w. I just hate hyper flash, to distracting to me. I'd be staring at the blinker instead of turning.
Rickalicka18
by TBYODA » Wed Jan 27, 2016 11:01 pm
This is correct thus you need a load resistor in line.
by Berettaspeed » Thu Jan 28, 2016 1:31 am
if something is below the amperage required, the flasher will blink like a bulb is out, you may have wiring issues somewhere. Most bulbs flashing quick because of amperage drop. By design.
If headlamps seem fine and not dim, then its more localized to the turn signal/combo switch circuit. Sometimes voltage drops can be seen sometimes they cannot. Some things run on 5v and others 12v. Try and find amperage specs and when the flasher is designed to speed up. Im willing to bet amps are dropping but enough is allowing the good bulbs to still "function".
Good luck :)
this is just what i would think.
Berettaspeed
by Chango » Thu Jan 28, 2016 2:06 pm
Berettaspeed wrote:if something is below the amperage required, the flasher will blink like a bulb is out, you may have wiring issues somewhere. Most bulbs flashing quick because of amperage drop. By design.
Good luck :)
Ill look into this, thanks.
Like I mentioned, its a service bed, so the lights in the rear may have just a small amount of amp difference than the stock tail lights??
Chango
by Rickalicka18 » Thu Jan 28, 2016 6:26 pm
That would make sense. My dads work truck have to have two leds wired together (one of the leds actually being visible) in order for his tail lights to stop hyperflashing... Except yours aren't leds. Might be worth it to find out what the kind of bulb you have in the blinker and compare the amperage to the stock one.
Rickalicka18
by TBYODA » Thu Jan 28, 2016 9:00 pm
I have had a bad hazard switch cause this, also the wrong or heavy duty flasher installed.
by jrivs4x4tb » Sat Jan 30, 2016 8:23 pm
Did you check to see if there was a sufficient amount of blinker fluid left in the flux capacitor?
Sent from my LG-H901 using Tapatalk
jrivs4x4tb
by Rickalicka18 » Sat Jan 30, 2016 9:26 pm
jrivs4x4tb wrote:Did you check to see if there was a sufficient amount of blinker fluid left in the flux capacitor?
Lol.
Rickalicka18
Return to Electrical / Radios
