Scanguage is here:(
by oChaws » Sat Nov 14, 2015 5:43 pm
So I just got me Scanguage ll in from Amazon. I started messing around with it and all and it's awesome!!!! The features are great!!! The only thing is.... I bought it to monitor Trans Temps (TFT) so I went through the process of putting the codes in for that sensor. My TB is an 08 and in fact uses CANSF protocol. With that being said, that is the code I used. For GM vehicles. Once I got it in and double checked it, I tried to use it on my way to work today. And I added it to my 4 gauges and it read 32 TFT. The entire ride.... Did not change from 32. So on the Scanguage site, it says some Xguages need to add (01) to the end of the first code. So I tried that and made an entirely separate code with the (01) added and it didn't not read any number..... I am confused!!!!!!! Has anyone else had this happen? I know most of you fellas use these on your modded TB's and I would like it to work for the one thing I bought it for........ Thanks all!! Btw I would've contacted their support first but they will just say not all sensors are supported. But for 08 it says there are ZERO restrictions!!!!
oChaws
by Aries » Sat Nov 14, 2015 10:45 pm
I went through the same thing with my 02. It got so confusing I had to call customer service and they walked me through it.
Aries
by oChaws » Sat Nov 14, 2015 11:08 pm
Aries wrote:I went through the same thing with my 02. It got so confusing I had to call customer service and they walked me through it.
Thanks for the reply!! So it was doing the same thing? I'm just afraid I wasted like $150
oChaws
by HARDTRAILZ » Mon Nov 16, 2015 10:57 am
Barton may be able to help you. I think he had the info on getting it to work correctly.
by JD8181 » Mon Nov 16, 2015 1:35 pm
I entered about all the codes (with and without the 01) on my 2005 and went through them all and just found the ones that worked. I have not had any problems with any of my gauges. I had an original scan gauge (big square box from about 11 years ago) and every once in awhile it would freeze up and I had unplug it and restart it. I haven't had to go that with my 2, but might be worth a try.
2005 Trailblazer 4x4
4.2
3.42
Mark's 3" lift
PCM of NC
.........wanting so much more!!!!!!
JD8181
by oChaws » Thu Nov 26, 2015 4:13 am
So I called support.... And the had me try the Allison teams code... Works beautifully!!!!! The woman on the phone was so knowledgable even down the the make and model of my TB!! 18384737282 Thumbs Up!!!!!!
oChaws
by Aries » Thu Nov 26, 2015 11:48 am
:woot:
Aries
Return to Electrical / Radios
