FRS radios?
by Jrgunn5150 » Fri Mar 20, 2015 12:53 pm
We need two way radios here at work, our paging system leaves much to be desired for communication purposes.
I guess, we used to have two way radios, but the need for FCC licenses was determined to be too costly. So anyway, we have three pants here, spread a crossed about 60 acres, with a big chain link fence and train tracks splitting it in half. Not to mention, we're in cinderblock buildings with steel roofs, casting aluminum, and machining it with steel CNC's.
So not an ideal situation for a low powered radio. FRS is pretty readily available, but I don't think it will have the needed power. Is CB an option? I don't really care if other people hear us all that much. Any other ideas? I really don't know alot about radios, so I'd appreciate the help.
by KE7WOX » Fri Mar 20, 2015 9:14 pm
Have they looked into the business band? That's a step up (it's what Target, Walmart and a lot of other retail stores use), but it's not a full system (with repeaters, fancy pre-programmed radios or anything like that). Another option is MURS, but radios aren't widely available (a few companies make them), you really gotta look for them.
FRS will most likely be useless, as it's limited by law to 0.5W, throw in a vehicle or building and you're done. CB could be an option, but there are few options for handheld radios, and they're typically large and heavy.
by AA1PR » Fri Mar 20, 2015 9:41 pm
Theres always MURS several "DOT" channels int eh VHF band would work
license free & you're allowed 2watts RF output
1966 Stevens M416 trailer too
AA1PR
by Jrgunn5150 » Tue Mar 24, 2015 6:46 am
KE7WOX wrote:Have they looked into the business band? That's a step up (it's what Target, Walmart and a lot of other retail stores use), but it's not a full system (with repeaters, fancy pre-programmed radios or anything like that). Another option is MURS, but radios aren't widely available (a few companies make them), you really gotta look for them.
I'm honestly not sure, I just know they had some radios, licensing got too expensive, and they're in a closet somewhere now lol.
I will check out the MURS systems, thanks guy's!
Return to Electrical / Radios
