led light bar mounting
by dgirardi » Wed Sep 25, 2013 3:44 pm
So I took a chance and bought a 42" light bar, and am trying to figure out how to mount it on the roof rack. Any ideas? It is 44" wide, by the way.
Once I get it on ill post some pictures, and update in a couple months to see how reliable it is.
dgirardi
by Cable810 » Wed Sep 25, 2013 3:53 pm
I think Drburke has mounted his to his roofrack think it was 42" viewtopic.php?f=74&t=4352
by mikekey » Wed Sep 25, 2013 4:07 pm
Post a picture and we can give you some better ideas.
by galacticfuzz » Wed Sep 25, 2013 4:15 pm
If the light bar doesn't reach to the rails you could always get a piece of flat steel and use that in place of a square bar. Minor fabrication involved. But like stated pics would help.
― Antonio Porchia
galacticfuzz
by dgirardi » Wed Sep 25, 2013 5:07 pm
Ill upload a picture when I get off work
dgirardi
by Regulator1175 » Sat Sep 28, 2013 11:29 pm
dgirardi wrote:Ill upload a picture when I get off work
Wow, that is one hell of a long shift you work!
by Moots1288 » Sat Sep 28, 2013 11:56 pm
Maybe he's working a 4 day straight shift!
by dgirardi » Tue Oct 01, 2013 8:31 pm
i've been working 12-14 hour days, lol. i'm a car audio fabricator/installer, and i get paid straight commission. if people bring me money, ill work all day long.
dgirardi
by dgirardi » Tue Oct 01, 2013 8:33 pm
this is basically what i have. 44" total width.
http://img1.cdn.nobodybuy.com/Y201106M1 ... 21-240.jpg
dgirardi
by 1brushscrubber » Thu Oct 24, 2013 11:35 pm
You could do like I did for my scanner antenna mounting (3 of them) and run a 1x1 square tube across the roof racks. I made my own insert with a welded nut on the bottom side of the insert (had to grind a little off the top of the nut) and then bolt down the square tube. I've used this same idea to mount 2 flat steel pieces to hold my MX7000 amber lightbar when I had it on the trailblazer.
Jake
1brushscrubber
Name: Jake Musselman
by navigator » Fri Oct 25, 2013 8:57 am
for my roof rack I took a large washer and cut part of the top and bottom off so it was only 1 Inch top to bottom. I then put it on a bolt and tightened a nut up real tight. This effectively gave the bolt a wide head to catch ont he sides of the rail. I made 4 of these and slid them in the rail of the roof mount and set the rack on and put another washer and bolt on top and bolted it down.
by drburke » Sat Oct 26, 2013 5:18 pm
Where the wind fairing goes, I had two fastening holes on each end that coincided with the mount points on the light bar's feet. I rigged up a secure mount based on this and washers/nuts. I ended up selling the rack and the bar to a friend. The rack and the tire up top was a gas killer and made it top-heavy. Coupled with disco'ed sway bars, I wasn't comfortable. I'll end up buying another bar again because the light output was absolutely out of this world, though I'll have to fab up a separate mount for it.
FYI, depending on the rack and its placement, half of the light output will hit the roof and reflect up because it sits far back.
drburke
by Trail X » Mon Oct 28, 2013 3:10 pm
Get that sucker up front on the roof. Get some blind hole rivet nuts and mount it wherever you want.
by djthumper » Mon Oct 28, 2013 8:03 pm
Get the blind hole nut-serts with the sealer and be good to go.
Return to Electrical / Radios
