No write up on the front lights... but here's the link.
viewtopic.php?f=27&t=1295&hilit=roofNo wiring or routing pics. I removed the 3 rear rail bolts. I drilled the holes into the back of the rails and ran wire through each hole. I then ran the wires under the rails and down the outside rear glass seal. You can't see ANY wiring at all unless you're really looking for it. Once the wire reaches the end of the seal, it loops under the tail light. I tapped into the black & brown wire on the driver side, black & brown/white on the passenger side. They come on with parking, no brake or turn.
