CB Installed
by SteveTB03 » Tue Jul 06, 2010 11:55 am
Ok so I finally got a CB yesterday install was straight forward (except for the power wires)
I made a bracket out of some steel plate and mounted it above the drivers side taillight where the rear hatch closes then ran 20' of RG58 cable to the front where I mounted it under the dash.
To power up this bad boy I just tappped the power and ground wires of the CB into the power and ground wires for my roof light switches which are right next to the CB.
EQUIPMENT:
COBRA 18 WX ST 2
20' of RG58 Coax
3' Fire Stik 3/8" screw in
As of now I don't know what happened to my camera (moved to Seattle) so I cannot post any pics of the install and what it looks like for now.
I can't get anything on any of the 40 channels I have including the emergency channels 9/19??? Maybe no one ever uses CB anymore. But I do get the weather station on it.
Go Big & Go Broke
SteveTB03
by Hatchet669 » Wed Jul 07, 2010 7:42 pm
cool... lets see the pics come on man... made an antenna holder for my trailer hitch for temp... gotta love have free welders and steel at work lol...
Hatchet669
by fishsticks » Wed Jul 07, 2010 10:30 pm
Channel 17 should get you some chatter.
I was up that way yesterday and the truckers up there are very good about "bear spotting." :)
by johnburgelin » Wed Jul 07, 2010 11:03 pm
ive got just a little magnetic antenna and i've got no problem hearing ppl, hmmm.
johnburgelin
by SteveTB03 » Wed Jul 07, 2010 11:26 pm
I mean I don't know if I've heard anybody or not I mean I just tried it for maybe an hour, and I'm still learning as to how I work it and what squelch is and its difficult to figure the CB out
but ill check out 17 for sure
Go Big & Go Broke
SteveTB03
by fishsticks » Wed Jul 07, 2010 11:56 pm
Turn RF Gain all the way up.
Turn Squelch all the way down.
You should hear something on 17.
RF Gain lets you pick up weaker signals.
Squelch is the threshold control of what breaks "silence" on your speaker. Too low and you'll hear background static all the time. Too high and you won't hear when anyone is talking.
You adjust both for your situation.
by SteveTB03 » Thu Jul 08, 2010 12:35 am
How do I do rf gain?
All I have is a volume knob, a squelch knob and a channel knob and a scan button, a 9/19 button, a weather channel button and a button that gets rid of outside noise.
Go Big & Go Broke
SteveTB03
by KE7WOX » Thu Jul 08, 2010 1:12 am
The Cobra 18 and 19 I/II/IIIdo not have an RF gain knob, just volume and squelch. IIRC my 19 DX IV does have RF gain. I've not seen RF gain in many of the smaller / cheaper units, it's mostly in the higher end shiny units.
by Hatchet669 » Thu Jul 08, 2010 4:56 pm
is your ground good... mine was kinda quiet after i changed the antenna location... wasnt a good ground or just not a good enough connection on the wire to the antenna...
Hatchet669
by SteveTB03 » Thu Jul 08, 2010 5:49 pm
Ground should be good its connected to the body and I think that the antennae has a good connection... ill have to check it all out again.
Go Big & Go Broke
SteveTB03
by Trail X » Thu Jul 08, 2010 9:13 pm
Did you use a fire-ring? If so, make sure those plastic washers are in exactly the right place... someone else on here ran into the problem and effectively bypassed his antenna.
by SteveTB03 » Thu Jul 08, 2010 9:39 pm
I knew I should have put that plastic washer on :wallbash: I figured it wasn't needed but now I see thanks JD ill go put it on now
EDIT: ok so I put that plastic washer on and it fixed the problem now I can hear people so thanks.
Go Big & Go Broke
SteveTB03
by djthumper » Fri Jul 09, 2010 1:12 am
And you thought you had spare parts... :raspberry:
by SteveTB03 » Mon Jul 26, 2010 7:20 am
Alright guys so here's some pics of the install!!
Go Big & Go Broke
SteveTB03
by Hatchet669 » Mon Jul 26, 2010 6:17 pm
same one i got...
Hatchet669
by SteveTB03 » Mon Jul 26, 2010 7:23 pm
Hatchet669 wrote:same one i got...
Really!! How do you like it??
Go Big & Go Broke
SteveTB03
by Hatchet669 » Tue Jul 27, 2010 9:04 pm
couldnt live with out the weather channels... i use it every time i'm on the road... no matter where i'm at i can get a weather report... when i had my cheapy antenna on my roof got great reception... i have it on a home made trailer hitch and not getting good reception.. but i know its not high enough... gunna be going to a fire stick eventually...
Hatchet669
Return to Electrical / Radios
