Fire Starters
by Trail X » Tue Apr 01, 2014 10:09 pm
What is the benefit of a mag striker vs a lighter like the peanut lighter?
by DirtyBacon04 » Wed Apr 02, 2014 12:04 am
apples to oranges, JD.
Mag strikers wont produce flame on their own, only sparks.
lighter is limited on fuel, for one. With a mag striker, you can shave a small pile of magnesium on to your tinder, and it'll catch a spark super easy. The good thing about a lighter like that is that even if you're out of fuel, you still have a good sparker.
Mag strikers can sit under water for days, all you have to do is wipe if off and it's ready to spark. (just make sure the other item is high-carbon steel in order to get a strong spark)
by dvanbramer88 » Wed Apr 02, 2014 5:22 pm
prepper1212 wrote:you really don't want a metal match on a key ring in your pocket could become a enLIGHTing experience. especially in the pocket of some cotton paints.
So everyone carrying a zippo in their jeans pocket is a fireball waiting to happen?
I'm not buying it.
by Trail X » Wed Apr 02, 2014 5:22 pm
So, basically, the mag lighter is good for a long-term survival scenario where you are jumping from place to place. A fluid lighter is limited by its fuel quantity, and might be better suited for short term survival scenarios, or a stay-in-place survival scenario where you can keep an ember living?
Eta, in a pinch, can a standard lighter create enough sparks for regular tinder?
by Conner299 » Wed Apr 02, 2014 7:06 pm
When I was smoking, a regular bic lighter would last at least a month. That was an average of 20 smokes a day. Plus, all the times I used it for utility purposes. That's over 600 uses, on average. Plus, if you've ever taken one apart, the flint is almost twice as long as a standard zippo. Just out of curiosity, I used one with the metal cowl removed, and had no problem starting a fire from scratch.
Conner299
by nvrs » Thu Apr 03, 2014 12:20 am
how about cardboard dipped in wax, stove pellets in muffin cups with wax drizzles and visco cannon fuse ,or chainsaw noodles soaked in diesel then coated with wax.
nvrs
by DirtyBacon04 » Thu Apr 03, 2014 9:25 am
JamesDowning wrote:So, basically, the mag lighter is good for a long-term survival scenario where you are jumping from place to place. A fluid lighter is limited by its fuel quantity, and might be better suited for short term survival scenarios, or a stay-in-place survival scenario where you can keep an ember living?
Depends on your tinder. Char-cloth and cottonballs in pet. jelly will catch just about any spark. The key with tinder is to make it as light and fluffy as possible.
But to answer your question, yes, it will work as a sparker.
by navigator » Thu Apr 03, 2014 9:39 am
I was at work one time and dropped a cheap lighter and it broke sending lighter parts across the store.
I'm sure it was due to the pressure of the compressed fuel but it did help me learn to treat them more carefully.
by KingBird » Thu Apr 03, 2014 9:53 am
KingBird
by Trail X » Thu Apr 03, 2014 11:30 am
Well, I'm sold. Split pea for me I think.
by boog2006 » Thu Apr 03, 2014 6:12 pm
Boog2006 Build Thread
boog2006
by Conner299 » Thu Apr 03, 2014 7:46 pm
If you have a zippo, already, you can accomplish something close to the peanut lighter. Just cut a piece of old bike inner tube close to half the height of the zippo. Then, just slide the zippo into it. Your fluid will last a good bit longer than normal. Maybe not as much as the peanut lighter, though. Still, neither would be my first choice.
Conner299
by AA1PR » Sat Nov 08, 2014 9:14 pm
I have several stashed here & there of magnesium fire starter blocks like this ~ http://www.amazon.com/Genuine-Issue-Mag ... B0002X1IOM
& theres usually enough natural stuff in the wilds for starter material, cattails, milkweed pods, dried grass etc
1966 Stevens M416 trailer too
AA1PR
Return to Camping / Survival
