PLANNING: TECORE VI - 2012 Spring Run - 4/27-4/29
by Trail X » Mon Apr 09, 2012 8:38 am
Updated
CONFIRMED:
Gordinh80
JamesDowning
Onelow1ton
Dirty Anton
Mudwheelin
BIGEZZYK
snowmirage
MAYBE:
Nakashige
themightysteveo
Mooseknuckle
Hope you can make it Moose. Think of it as a valuable life experience though. Now I bet you'll stay a good 30 feet behind anyone. :)
by Mooseknuckle » Mon Apr 09, 2012 11:33 am
Lol. Yeah problem is I was a good amount away from him he should have went forward instead he floored it backwards. We were all yelling at him to stop after he moved ten feet but he didn't listen. I actually went to him and said go forward my truck is in back of u. I also said if you decide to go backwards let me know I will move. Lol
I don't dial 911
Mooseknuckle
by Mooseknuckle » Mon Apr 09, 2012 11:40 am
Also your right we have rear wheel drive. Let me re phrase. The transfer case seems to be locking in gear I feel it and hear it but the front wheels aren't engaging. My four wheel was good after the accident I took it out of 4 hi then put it back in it was working fine then i saw just the rears spinning when I was attempting to go through some sand.
I don't dial 911
Mooseknuckle
by themightysteveo » Tue Apr 10, 2012 2:24 pm
Sorry all... I am no longer going to be able to attend. Sincere apologies.
themightysteveo
by Trail X » Tue Apr 10, 2012 3:38 pm
BOOOO.... :angry whip:
CONFIRMED:
Gordinh80
JamesDowning
Onelow1ton
Dirty Anton
Mudwheelin
BIGEZZYK
snowmirage
MAYBE:
Nakashige
Mooseknuckle
by hobbstisdaman » Wed Apr 11, 2012 9:48 pm
Hmm. I think I have drill that weekend...
hobbstisdaman
by dirty anton » Sun Apr 15, 2012 10:05 am
fri the 13th i lost my 3/4 clutch in my tb! got it sitting in my garage. hopefully can get this issue resolved by next weekend so i can drive it a few days before the 27th. fingers crossed.
dirty anton
by onelow1ton » Sun Apr 15, 2012 2:41 pm
Hope you get it fixed
2011 Colorado Z71 Crew Cab 5.3 v8 SASed, 37x12.5x16.5 wrangler MT/R,recentered h1 beadlocks, Doug thorley headers, mbrp exhaust , ARE topper , rtt, x20 10k winch
expo build http://www.expeditionportal.com/forum/t ... rado-build
onelow1ton
by dirty anton » Sun Apr 15, 2012 4:26 pm
yep the classic 3 4 clutch pack went out in the trans. at least i was within ten miles from home. limped home very slow. let it cool off then it slipped really bad for a few mins then back to not shifting out of 2nd. i am optimistic in being able to fix it for the trip.
dirty anton
by Nakashige » Sun Apr 15, 2012 11:07 pm
If my SAS is done i will make the trip i have rge funds for it
Nakashige
Vendor
by Trail X » Mon Apr 16, 2012 11:12 am
dirty anton wrote:yep the classic 3 4 clutch pack went out in the trans. at least i was within ten miles from home. limped home very slow. let it cool off then it slipped really bad for a few mins then back to not shifting out of 2nd. i am optimistic in being able to fix it for the trip.
Hope you can figure it out. You sure it isn't a valve issue? Maybe the #4 check ball got lodged in your spacer plate - did you replace the plate when you did the kit?
Nakashige wrote:If my SAS is done i will make the trip i have rge funds for it
You must have the fastest fab guy in the world to even suggest that. :raspberry:
by dirty anton » Mon Apr 16, 2012 11:34 am
The valve body looked good,i did a plate mod were it fixes the oval holes,had one oval hole. There was alot of clutch material in the pan.l
dirty anton
by Nakashige » Mon Apr 16, 2012 10:28 pm
I was told 2 weeks once axles are here
Nakashige
Vendor
by Gordinho80 » Fri Apr 20, 2012 2:26 pm
So we're getting close...
I'm planning on meeting JD in Pikesville, MD, of of 695 at 8:45-9AM on Friday Morning. Its about 160 miles from me, so I'll be topping off and we'll be heading out. Anyone interested in convoying with me from Central NJ... let me know. I'm 20ish minutes from 95, which is what I'll be taking down to MD.
by Mudwheelin » Fri Apr 20, 2012 11:29 pm
I'm all geared up for my 3657 km drive which works out to 1day 16hours. Can't fricking wait! Hopefully the weather stays nice!
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by NC_IslandRunner » Fri Apr 20, 2012 11:59 pm
Mudwheelin wrote:I'm all geared up for my 3657 km drive which works out to 1day 16hours. Can't fricking wait! Hopefully the weather stays nice!
Sorry but we're gonna need you to convert and distance traveled after you cross the border to Miles, So it will be x-km and x-miles to TECORE VI........ :poke: :finger:
by Trail X » Sat Apr 21, 2012 7:58 am
Wow! Thanks for making the trek! Hopefully it will be worth your drive. :)
by Mudwheelin » Sat Apr 21, 2012 11:12 am
Ya no kidding. Just had an oil change this morning and the rear diff plug is stripped. They couldn't get it off, so off to a welder I go. The front diff was no problem.
Build Thread:
Mudwheelin
by Trail X » Mon Apr 23, 2012 10:13 am
Hope you guys don't mind - I'm going to try to produce an even better video of tecore this year. I've made an investment in some equipment that could yield some cool angles and shots, but it may require a little extra set up time when we get to some spots.
by snowmirage » Mon Apr 23, 2012 6:58 pm
Unless I get time to remove the steps from my truck before then I refuse to sign a waiver releasing any video or pictures of my poor truck lol :P (but seriously if I have to cut them off they're coming off any day now...)
snowmirage
Return to Eastern U.S.
