New Lift Design (need some input)
Products offered by our vendor: markmc
Moderator: markmc
by Zero » Fri Dec 17, 2010 2:45 pm
I think I read earlier that january was a possibility for release.....and that you might offer a spring strut and lift pre built combo for those who want a bolt in application. Any update on this? I already have negative rake in the front, and when my steel bumper comes, it will be way worse.
by HARDTRAILZ » Fri Dec 17, 2010 2:51 pm
Isnt negative rake when the front is higher than rear?
by markmc » Fri Dec 17, 2010 2:57 pm
Zero wrote:I think I read earlier that january was a possibility for release.....and that you might offer a spring strut and lift pre built combo for those who want a bolt in application. Any update on this? I already have negative rake in the front, and when my steel bumper comes, it will be way worse.
Kyle will be getting his kit for testing next week.
Once he gives me thumbs up, production will start.
Wheel Adapters is literaly waiting with his finger on the machine start button..
markmc
Rank: Mall Rated
by Rob93 » Fri Dec 17, 2010 4:22 pm
Rake= rear higher than front
Negative rake= front higher than rear
Rob93
by Zero » Fri Dec 17, 2010 6:31 pm
My bad.....to clarify....I have too much positive rake as it is (front lower than rear). :thumleft:
by Zero » Sun Dec 19, 2010 8:25 pm
Mark, any word on if you will offer a prebuilt lift, spring and shock combo when this kit is ready to sell? I need to start planning things out.
by HARDTRAILZ » Thu Dec 30, 2010 3:09 pm
I got a package waiting at home for me...
by Hpimichael02 » Thu Dec 30, 2010 3:10 pm
watch it be a purse of shoes for your mom or you girlfriend/ wife
that always happens to me
Hpimichael02
by HARDTRAILZ » Fri Dec 31, 2010 2:36 am
I have just recieved and installed the new hardware. Will update as I test, but I have to say THANKS Mark. Solid set-up and I am sure we will talk tomorrow. Also thanks to Regulator for all the help with the install.
But some pics for those that want to see...
Old...
Mounts were toast...
Centers were busted out of both and lodged on the shafts.
New...
Mounted...
Installed and sitting pretty...
I have more pics, but wanted to get something up here. I gained 1.25 inches, but i think part is due to the busted mounts that I thought were springs settling. I have Bilstien HD and the 88 springs, FYI. Making my tires look tiny, but may be a bit much with the combo. Shafts didnt look too bad, but I always tell myself that. The truck feels more solid and rides a ton better. Will keep y'all posted.
by Opeth » Fri Dec 31, 2010 3:08 am
Love it, awaiting to see your full review of them.
by markmc » Fri Dec 31, 2010 4:30 am
Sweet!!!!!
looks like we need to work on that third hole..
:cheers:
markmc
Rank: Mall Rated
by JamesDub » Fri Dec 31, 2010 5:17 am
Hey Mark with these suckers work with my 2" longer springs ? I'm running a 1" Smaxx spacer ontop of them now .
Or would my springs be too compressed ?
The DubMobile is getting a makeover !
JamesDub
by markmc » Fri Dec 31, 2010 5:33 am
JamesDub wrote:Hey Mark with these suckers work with my 2" longer springs ? I'm running a 1" Smaxx spacer ontop of them now .
The new design should work fine with your springs.
Hail to you James!!
Your the guy that started my Obsession with lifting and led to all the products i offer..
markmc
Rank: Mall Rated
by Zero » Fri Dec 31, 2010 10:25 am
What did you end up replacing the stock piece of rubber with? Did you go with a polyurathane like bushing that BDS uses in there kits?
And just throwing this out, I know they are not done, But I would like mine to use all 3 bolts to mount.
Now that these are actually on someones truck, do we have a better release date in mind? and price? will you be selling a shock, spring and lift pre built set?
by JamesDub » Fri Dec 31, 2010 10:30 am
Thanks Mark .
Can't wait to see more pics of the installed kit and read some feedback on how it performs . The DubMobile is getting a major re-work over the next 3 months :twisted: .
Great work on your design like always . Third hole too please :thumleft:
JamesDub
by Hpimichael02 » Fri Dec 31, 2010 12:14 pm
kyle are your running them with out the thrid hole???
it was my unsterstanding that taht 3rd hole was a must for the version you have
Hpimichael02
by HARDTRAILZ » Fri Dec 31, 2010 1:21 pm
Can't quite get 3rd hole. I don't see it as any different than before. My center washer never toched metal or provided support. Two bolts are all that connected before.
by Hpimichael02 » Fri Dec 31, 2010 2:15 pm
your probably right kyle, thats just what mark was saying when we installed the steel one... but looks damn good man, really good.... i need the 88 springs
Hpimichael02
by Regulator1175 » Sat Jan 01, 2011 1:31 am
For the third hole to be able to fit correctly the entire spacer needs to be at least an inch wider. The hole on the spacer was barely visible, and you could see the outside edge of the spacer through the hole. The other option is to elongate the hole on the vehicle, and us a larger washer with the bolt. I think that will be the easier option then a redesign of the spacer. Just my thoughts following the install yesterday.
by markmc » Sat Jan 01, 2011 4:06 am
Zero wrote:What did you end up replacing the stock piece of rubber with? Did you go with a polyurathane like bushing that BDS uses in there kits?
Went with a Monroe mount system. they had the size and shape i was looking for.
yes, some day when i dont have so many irons in the fire.. an assembled bolt in strut is on my to-do list.
might have to delete the third hole idea.. just have to wait till after the testing to make that call..
Honestly i think the new design is pretty much bullet proof with just the 2 mounting bolts..
markmc
Rank: Mall Rated
Return to Liftmeister
