Rear Control Arms!
Products offered by our vendor: gotricebih
Moderator: gotricebih
by Gordinho80 » Thu Jan 20, 2011 5:07 pm
JamesDub wrote:Truck is back together :cheers: .
The Skyjacker springs added 2.5" more lift than my Japanese 2" taller than OEM springs .
The center of my rear wheelwell went from 41.5" to 44" . Was a little worried I couldn't fit out the garage door ,....fits by 2" :D .
The upper control arms were a trial by error install , switch em around till they seem to fit right . Had to yank on the axle with some ratchet straps to pull the rear into place . Didn't have a 21mm wrench, socket :roll: so I got by with two 13/16th wrenches . Tire is now centered in the wheelwell .
Lots of climbing around on the ground and sore back,arms,legs and knees but its all back together !
Pics to come as soon as I get my camera back .
:need pics:
How does the driveshaft engagement look? Wondering if upping the rear suspension so much with the addition of the longer controls arms would push the limits of the driveshaft, especially with flex...
by dirty anton » Wed Jan 26, 2011 7:50 pm
wanted to see if there is any updates on the longer control arm install, brake line relocation axle issues and overall performance. thanx
dirty anton
by dirty anton » Fri Feb 11, 2011 11:31 pm
installed rear control arms. these are really well made and went on perfect! i did however replace the straight zerks with elbows. makes it easier to grease. the wheel is nice and centered now. relocated the e brake line straps to the edge. an inch or so from where they were. and added an inch long bracket for the brake lines.
looking good so far.
rear control arms
(14.24 KiB) Downloaded 325 times
brake line's relocated
(13.03 KiB) Downloaded 325 times
centered wheel
(15.6 KiB) Downloaded 325 times
dirty anton
by dirty anton » Fri Feb 11, 2011 11:34 pm
elbow zerks
elbow zerks
(9.72 KiB) Downloaded 324 times
dirty anton
by dirty anton » Mon Feb 21, 2011 9:28 pm
wanted to update on these longer rear control arms. this is what were working with.
took a pic of axle/tc case to show the 1 inch gap the axle now sits. thoughts? or comments?
(13.76 KiB) Downloaded 295 times
dirty anton
by SteveTB03 » Mon Feb 21, 2011 9:35 pm
Is that a picture of the slip/fixed yoke on the tcase?
Go Big & Go Broke
SteveTB03
by dirty anton » Mon Feb 21, 2011 9:40 pm
yea
dirty anton
by SteveTB03 » Tue Feb 22, 2011 2:25 am
I would probably say that it might be time for some longer driveshafts for you guys.
Go Big & Go Broke
SteveTB03
by JamesDub » Sat Feb 26, 2011 10:36 pm
Heres mine .
Driveshaft looks pretty much the same .
The DubMobile is getting a makeover !
JamesDub
by Trail X » Tue Jun 21, 2011 2:28 pm
How are the bushings holding up guys?
by gabepiceno » Thu Jan 12, 2012 5:05 pm
does anyone know if these are still available for purchase i noticed this thread has been dead for a while now and i have emailed and pm'd him whith no reply? i am planning on running some 35x12.50x17 and would love to get a set so i can avoid rubbing the front of my rear wheel well thanks for any info guys.
gabepiceno
by Trail X » Thu Jan 12, 2012 5:12 pm
I had spoke with him a couple months ago. I think he's still around. He just doesn't visit this site often.
by gabepiceno » Thu Jan 12, 2012 5:19 pm
JamesDowning wrote:I had spoke with him a couple months ago. I think he's still around. He just doesn't visit this site often.
thanks for the quick response james i guess i will wait a little longer hopefully he replies to my email soon.
gabepiceno
by mikekey » Sun Mar 10, 2013 9:22 am
Did you ever get in contact with him?
Return to GR Fabrication
