replacing wheel hubs, what else would you replace?
by distiller » Sat Jan 19, 2019 1:02 pm
Long time lurker, first time poster...
I've had my '02 Envoy for a year and a half, it now has 107,000 miles.
Replacing the wheel hubs & CV drive shafts have been on my to-do list, the passenger hub is starting to whine so I need to get these parts and git'er done.
My question is while I have the front end torn apart, what else would you replace? Struts, upper ball joints & sway bar links are new.
I'm going to install new brake dust shields, rotors & pads. calipers seem OK but with 16 years maybe they should get on the list. Also going to install new lower control arm / lower ball joint assembly. I just don't want to put old parts back on and regret it later. Any input from your expreience is greatly appreciated!
distiller
Name: Greg Christmas
Vehicle: GMC Envoy XL
by Diacom » Sat Jan 19, 2019 11:35 pm
Go through the disconnect while you're in that far.
by distiller » Sun Jan 20, 2019 1:43 pm
Diacom wrote:Go through the disconnect while you're in that far.
Thanks, I was at first worried it was the disconnect but am sure it the hub.
distiller
