Front end noise
by oefootball_70 » Wed Dec 07, 2016 7:02 pm
I know, there are a ton of these threads. I'm having trouble understating one persons explanation of an issue and comparing it to mine.
I am having a noise that doesn't sound like grinding, but rather metal rubbing. Not high pitched. It's definitely something rotating and not popping. And from the front end.
I'm assuming it's a hub because it seems to go away at higher speed and doesn't get louder while braking.
My issue is, when I jack up my TB, should my front wheels spin freely? Or with ease? They aren't stuck by any means, but not really freely spinning. I wasn't sure if that was a sign of an issue either.
2007 i6 4x4 TB
275/65/18 Crosswind A/T
oefootball_70
by Nexus1155 » Fri Dec 09, 2016 5:05 pm
Honestly, if you can't see it. Maybe the inside pad of the front brakes are pretty low? Assuming you pushed away all of the brake shields
Nexus1155
Vehicle: GMC Envoy XUV
by oefootball_70 » Sat Dec 10, 2016 2:02 pm
Kind of embarrassing, but there were some small rocks or maybe salt in between the pads and rotors. Pulled ally the pads and everything is good to go now.
2007 i6 4x4 TB
oefootball_70
by ErikSS » Sun Dec 11, 2016 6:09 pm
Glad you got it sorted out. Rocks in the dust plate are common in these.
