Wheel bearing or tire noise?
by JD8181 » Sun Nov 08, 2015 9:21 am
Is there any real tell tell signs of weather the noise I'm hearing going down the road is a wheel bearing going out or just tire noise. I'm running cooper at3 that are probably 1/2 worn.
2005 Trailblazer 4x4
4.2
3.42
Mark's 3" lift
PCM of NC
.........wanting so much more!!!!!!
JD8181
by Trail X » Sun Nov 08, 2015 11:22 am
Rotate your tires and see if the noise stays the same or moves.
by JD8181 » Sun Nov 08, 2015 7:05 pm
I just had that done last week and and still have a humm.
4.2
3.42
Mark's 3" lift
PCM of NC
JD8181
by Rickalicka18 » Sun Nov 08, 2015 8:17 pm
I had a noise similar to that. And it turned out that my brake pad clips to hold the brakes in place had broken on each side and the brakes would never fully retract and it made a humming noise. Might be worth looking at.
Rickalicka18
by JD8181 » Sun Nov 08, 2015 10:17 pm
I'll check that out thanks. Any other things I should look for once I get it jacked up. And wheels off?
4.2
3.42
Mark's 3" lift
PCM of NC
JD8181
by HARDTRAILZ » Mon Nov 09, 2015 8:50 am
Does the noise change when turning?
by JD8181 » Mon Nov 09, 2015 1:09 pm
I tried that and it doesn't really seem to change when turning.
How long do the oem wheel bearing last most of the time. Mine is an 05 with 105k miles and as far as I know they are stock (I've had it for 5 years and 50k miles).
4.2
3.42
Mark's 3" lift
PCM of NC
JD8181
by HARDTRAILZ » Mon Nov 09, 2015 1:15 pm
I got over 100K including part lifted.
by BC backroader » Mon Nov 09, 2015 4:23 pm
Both of mine were gone at about 135,000 km (85k miles)
by navigator » Mon Nov 09, 2015 5:22 pm
The OEM bearings seem to fail a good bit slower than after market also. I remember when I replaced mine, I really couldn't tell with the bearing itself. I could drive straight until I heard the noise, then veer a little left or right and you could hear the noise change. Even with the stock bearing out it just felt like maybe the grease was a little thick. With my aftermarket you could tell they were worn by rotating in your hand.
by JD8181 » Tue Nov 10, 2015 8:01 am
Thanks for all the info guys. I'm thinking it's just tire noise. Maybe when they did rotate them they did get a little noisier. But when I turn back and forth the sound doing really change. And it just get a little noisier at about 45 and up. I'll give it a little more time and if it get worse I'll switch them out.
4.2
3.42
Mark's 3" lift
PCM of NC
JD8181
by v7guy » Tue Nov 10, 2015 11:52 pm
Generally the standard way to tell was on longer sweeping highway turns the noise would change if it's the hubs/bearings, but I do know off at least once where there was no obvious noise noticed until the envoy was impossible to drive straight and brake components were coming into contact with each other necessitating a convenience store repair.
