Headlights
by Trailblazin Ahead » Sat Oct 31, 2015 6:55 pm
Every now and then I'll be driving and my lights will shut off. They won't come back on uess I pull over and play with the switch a bit. With that being said is it a shortage recall or what please help
Trailblazin Ahead
by Rickalicka18 » Sat Oct 31, 2015 7:16 pm
Headlight fuse?
Rickalicka18
by KingBird » Sat Oct 31, 2015 9:37 pm
Try tapping on your high beam relay in the fuse box under the hood. I'm having issues with mine turning off like this when I switch between high and low beams. Highs work like gangbusters, lows may not come back on when I dim, so I just leave my high beams alone (I have rooftop lights that are brighter anyway).
I took my fuse box apart and tightened up the bolt that holds those plugs in the bottom of it, that seemed to work for a few months.
KingBird
