2007 head on an 2005
by Trailblazin Ahead » Thu May 14, 2015 6:41 pm
Will a 2007 Chevy trailblazer head work on a 2005 Chevy trailblazer. I heard the 2007 is a better head and that it helps performance and etc for the 4200 motor. Any insight would help thanks
Trailblazin Ahead
by Moots1288 » Thu May 14, 2015 10:25 pm
I believe it does, and it's 06+
by Trailblazin Ahead » Fri May 15, 2015 1:21 am
Does it better the performance, over the 2005 head I was gonna pick one up after I do my lift and armor. But wanted insight before I tell the owner of the junked 07 to pull the head for me
Trailblazin Ahead
by Moots1288 » Fri May 15, 2015 8:32 pm
Yes, it will help with performance.
by v7guy » Sat May 16, 2015 8:00 am
The cam cover needs to change from the plastic one to the later metal one and the coils are different on the 06 and up, they're a fair bit smaller. Additionally the fuel injectors are shorter on the late motors, I don't recall off the top of my head if the longer ones pop in there anyways.
You'll get some better airflow from the head itself, but some of the power increase came from a bump in compression from an updated piston.
Also be aware that the coolant temp sensor moves from the water pump neck to the head by cylinder 6, you'll need to at least make sure it's plugged.
by Trailblazin Ahead » Sat May 16, 2015 11:19 pm
OK thanks guys for all the helpful and useful answers. If and when I do it I'll have my local shop do it. I don't want to mess anything up but thank you again
Trailblazin Ahead
