Sorry I was away but im back and just did balljoints!
by jmar07 » Wed Apr 22, 2015 7:31 am
Hey everyone, Sorry i was away for awhile been really busy lately and just havent had much computer time. ANyways this past weekend I put new upper and lower balljoints on the TB and everything went great. Kickinhg myself now cause I know i need control arm bushings and of course when you buy the control arm it comes with the balljoint. Oh well though didnt have the money for all that right now anyway. Hope everyone is doing well!
jmar07
by v7guy » Wed Apr 22, 2015 10:59 pm
You can always replace the bushings in those arms... It's a job though lol
by tarsh » Wed Apr 22, 2015 11:04 pm
How bad is it? Mine is cherping with its new lowered stance
Take the path less traveled
tarsh
Name: Nathan Schroeder
by v7guy » Wed Apr 22, 2015 11:30 pm
Burn out the old, press in the new...
by tarsh » Wed Apr 22, 2015 11:43 pm
Bogus
tarsh
by Jrgunn5150 » Thu Apr 23, 2015 5:48 pm
MAP torch will do it
by jmar07 » Fri Apr 24, 2015 9:14 am
Not to sure about burning them out and pressing them in and all Ill probably just buy new arms and say screw it. The ball joint job isnt terrible. I rented the master ball joint press kit from advance(autozone only had a small set). The uppers literally took me 10 mins for both sides. The lowers are a bit harder. I used a MAP gas torch heated the old ones up and was able to hit them out with 3 good wacks no problem.
jmar07
by Eredin » Fri Apr 24, 2015 1:39 pm
I will say that these ball joints are some of the easier one's I've done. I went through the whole bushing replacement ordeal on the lower arms of my GTA, that sucked and is why I bought the whole assembly when I needed LBJs on the TBlaze. Remember, you'll likely need an alignment when you swap your lower arms, they have plenty of room to slide around in the frame. Else, mark them really well.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
