2002 on one tons
by Fastonthetrack » Wed Apr 01, 2015 12:00 am
Jrgunn5150 wrote:
Fastonthetrack wrote:well you dont ever want to put your leaf springs into a negative arch. soo if you bump stop them properly there is nothing to worry about either way.
Negative arch isn't that bad, there's millions of 73-87 Fullsize Chevy's running around with negative arch. Flat packs are best, because you're not fighting against arch for articulation.
you don't want to over extend your positive arched springs into a negative arch. reason being is over-sprung energy in an off camber situation could put you on your side.. thats why bump stops are important. You want to reduce the amount of push back you have, obviously. thats why good coilovers are the best route.
I bought some 46" michelins and some moto metals for street use. I also plan on getting the NP241 in this weekend since ive been waiting on the 6 bolt 4l60e adapter to 6 bolt NP tcase. then i need to address the drivelines again. I also need to notch the trans crossmember. I also plan on lowering the truck another 2-3" without the front and rear bumpers the truck looks much bigger than it really is.. There is not a ton of room between the front axle and the oil pan.
Fastonthetrack
by Fastonthetrack » Sat Apr 04, 2015 10:58 pm
no pics, but i got the NP241 ready to go in.. just need to figure out what to do with the VSS wiring... anyone know??
Fastonthetrack
by v7guy » Sun Apr 05, 2015 1:06 am
Supposedly using the front output on the stock wiring on the 241 works.
by Fastonthetrack » Sun Apr 05, 2015 2:21 pm
you mean plugging the factory front VSS sensor into the rear output of the NP241? The ECM only reads the signal from the rear driver VSS sensor.
Fastonthetrack
by Fastonthetrack » Wed Apr 08, 2015 12:50 am
Picked up some 46" michelins today for road use and mounted them on some brand new moto metals.. gonna look killer once i can get the truck out of the garage and mount them.
Fastonthetrack
by v7guy » Wed Apr 08, 2015 5:00 am
Fastonthetrack wrote:you mean plugging the factory front VSS sensor into the rear output of the NP241? The ECM only reads the signal from the rear driver VSS sensor.
Don't take my word for it cupcake! :raspberry: :mrgreen: :mrgreen:
All I know is the guy that just swapped the solid axles in his envoy on pirate said that worked after struggling with it for weeks. I didn't understand why it worked and neither did he, hence the "supposedly". Bout the fourth post down on this page...
http://www.pirate4x4.com/forum/chevy/18 ... ig-20.html
by Jrgunn5150 » Wed Apr 08, 2015 9:52 am
I've also read that thread, everyone kept telling him to use the other sending unit, finally he tried it out of frustration and it worked lol
by Cable810 » Wed Apr 08, 2015 10:42 am
I think thats what Steve and Mike did as well. Steve said something about it in his BS thread IIRC its somewhere in pages 12-28
by Fastonthetrack » Wed Apr 08, 2015 5:05 pm
Yes I read through those threads and Got input from steve. He's not sure what sensor it was exactly because of the many times he swapped back and forth. That's why I asked. If someone new exactly what sensor does what.
Fastonthetrack
by Trail X » Thu Apr 09, 2015 8:47 am
I wish I knew which was which, but I know one of the rear VSS is the ECM input, and one is the TCCM input. You should be able to just swap the plugs if your speedometer doesn't move.
by Cable810 » Thu Apr 09, 2015 3:58 pm
Dunno if this helps or not.
by Fastonthetrack » Thu Apr 09, 2015 11:13 pm
Yes that does help. thanks. The VSS is the one we need to use to send the speed signal to the ECM and onto the speedo.
Fastonthetrack
by Cable810 » Fri Apr 10, 2015 9:16 am
Good deal. I came across that picture a while back :lol: Took me a while to try and find it for ya
by Fastonthetrack » Thu May 07, 2015 9:38 pm
Got the np241c and the 46s installed.
http://i1005.photobucket.com/albums/af1 ... u1hxev.jpg
Fastonthetrack
by HARDTRAILZ » Thu May 07, 2015 10:17 pm
Tires look ready to chew on the body!
by v7guy » Sat May 09, 2015 1:48 am
Looks pretty spiffy, I dig it!
by onebigburb » Sat Jun 06, 2015 5:37 pm
truck is for sale seen it a week or two ago on cl. http://portland.craigslist.org/wsc/cto/5050717279.html
onebigburb
