maricard wrote:Today I changed for a second time a motor support. This time it was the driver side. It was very painful to replace it. Passenger side was easier two months ago. Anyway less motor vibrations but still have something wrong under the hood.
DirtyBacon04 wrote:I enjoy my massaging steering wheel and pedals. dont know what y'all are talking about!
Trail X wrote:maricard wrote:Today I changed for a second time a motor support. This time it was the driver side. It was very painful to replace it. Passenger side was easier two months ago. Anyway less motor vibrations but still have something wrong under the hood.
I chased a motor vibration for years and could never locate it. Replaced everything I could top-side.
It ended up being that my exhaust manifold had a crack in it. It wasn't enough of a crack to hear much noise, but it was enough for the ECU to attempt to compensate for what it thought was a lack of exhaust gasses on a few cylinders. The crack finally got bad enough that I noticed it, and with changing the O2 and the manifold, the vibrations faded away.
moose1 wrote:joined the crowd and removed the damn squeak maker out back.
maricard wrote:Trail X wrote:maricard wrote:Today I changed for a second time a motor support. This time it was the driver side. It was very painful to replace it. Passenger side was easier two months ago. Anyway less motor vibrations but still have something wrong under the hood.
I know that I have a crack on my manifold. But I didn't think that could be connected. Did you have a lot of difficulties to remove it? Did you remove it from the top or bottom? Did you break any bolt when you tried to remove them. It's not really expensive part specially on Ebay but look like hard to do.
I don't have any check engine light on, so is it possible that my vibration come from of my manifold crack?
moose1 wrote:Just an FYI on the manifolds. mine cracked at around 115k and while looking for parts and info I found out that GM extended the warranty period on these manifolds to 120k. I had the dealer replace it at 119.5k.
maricard wrote: I know that I have a crack on my manifold. But I didn't think that could be connected. Did you have a lot of difficulties to remove it? Did you remove it from the top or bottom? Did you break any bolt when you tried to remove them. It's not really expensive part specially on Ebay but look like hard to do.
I didn't have a check engine light either. There's no sensor in the engine that checks for exhaust gasses escaping from the manifold. The engine does however see that the O2 sensor sees less exhaust gasses when the cylinders near the crack expel their gasses. The O2 sensor reports this to the PCM as lean or rich burn in those cylinders (I'm not sure which). The PCM then attempts to compensate by adding more or less fuel to those cylinders. Those cylinders then get a non optimal combustion, which vibrates the engine. Sometimes you'll get a misfire code on that cylinder, but often you have to let the engine idle for a while to let the PCM attempt to tune out the vibration.
The manifold is a bitch to get out. I had two broken bolts before I started removing bolts. The remaining bolts all came out without issue. The manifold barely fits out of the bay, and the bolt access to some of the bolts sucks. The broken bolts were removed by welding a nut to the exposed stud. Also - if you get replacement bolts, be sure to get GM bolts that have the high temp locktite applied.
