GM Vehicle History Requests (BACK ONLINE)
by Philberto » Tue Dec 07, 2010 7:57 pm
I have recently determined that I have access to GM's vehicle inquiry system ver. 2 (VIS2), and with a VIN, I can pull up a report like the one below, on my own vehicle:
View Vehicle Summary
This screen allows GMVIS users to view the Summary of Vehicle Information, Field Actions, Service Information, Applicable Warranties, Transaction History, Service Contract(s) if applicable, Warranty Block, Branded Title information and OnStar and XM Radio information (if applicable).
Vehicle Information
VIN: 1GNDT13S462247814 Model: CT15506-2006 TRAILBLAZER 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 50 - FLEET
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Service Update Bulletins N070132 07132 SERVICE UPDATE-INV/CUST-OBD SYS IMPROVE-REPROG PCM-EXP W/8YR/80K MILE ECM WARR 06/27/2007 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 12/24/2005 10 MI 12/24/2008 36,010 MI
Emission Select State Component Lty Wty 12/24/2005 10 MI 12/24/2012 70,010 MI
ü Corrosion Limited Warranty 12/24/2005 10 MI 12/24/2011 100,010 MI
Certified Used Limited Warranty 12/24/2005 10 MI 03/24/2009 39,010 MI
ü Certified Used Powertrain Limited Wty 12/24/2005 10 MI 12/24/2010 100,010 MI
Emission Limited Warranty 12/24/2005 10 MI 12/24/2008 50,010 MI
Emission Select Component Ltd Wty 12/24/2005 10 MI 12/24/2013 80,010 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
06/23/2008 083755 ZFAT----Field Action Recall V1629 - 07132 Reprogram Engine Control Module (ECM) 51,422 MI
12/23/2005 A47814 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
For this vehicle:
→ View Vehicle Summary
→ Service Contract
→ Branded Title
→ Warranty Block
→ View Vehicle Build
→ View Vehicle Component Summary
→ View Vehicle Transaction History Detail
→ View Vehicle Delivery Information
→ Investigate Major Assembly History
Global Warranty Management: Site Map
Thought you guys would like that. I can also access RPO codes, Vehicle Component Summaries:
Vehicle Component
Component Code: 10-ENGINE ASSEMBLY Traceability: 512201298
Source Plant: V-CPC FLINT, MICHIGAN Part / Number Broadcast: NFS
Date Scanned: 12/23/2005 Time Scanned: 04:26:00 Scan Station: 01
Component Code: 35-STEERING COLUMN - SIR SYSTEM Traceability: 006523535
Source Plant: S-SAGINAW DIVISION SAGINAW,MI Part / Number Broadcast: XWM
Date Scanned: 12/23/2005 Time Scanned: 06:02:00 Scan Station: 05
Component Code: 60-TRANSFER CASE (4 WHEEL DRIVE) Traceability: 0BI595051
Source Plant: N- Part / Number Broadcast: FK
Date Scanned: 12/23/2005 Time Scanned: 04:38:00 Scan Station: 03
Component Code: 61-TRANSMISSION Traceability: 43382855
Source Plant: Y-HYDRAMATIC TOLEDO, OHIO Part / Number Broadcast: 6TDD
Date Scanned: 12/23/2005 Time Scanned: 04:35:00 Scan Station: 02
Component Code: 63-FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES Traceability: HAT53385
Source Plant: G- Part / Number Broadcast: UK2
Date Scanned: 12/23/2005 Time Scanned: 05:27:00 Scan Station: 12
Component Code: 65-REAR AXLE ASSEMBLY Traceability: 347073903
Source Plant: C-SAGINAW BUFFALO, NEW YORK Part / Number Broadcast: CN8
Date Scanned: 12/23/2005 Time Scanned: 05:30:00 Scan Station: 11
Component Code: 92-BRAKE PRESSURE MODULATOR VALVE ASSEMBLY Traceability: 00234234
Source Plant: K-KELSEY-HAYES JASPER, INDIANA Part / Number Broadcast: 3051
Date Scanned: 12/23/2005 Time Scanned: 07:00:00 Scan Station: 21
Component Code: AB-IR-MODULE ASM-INFLATOR Traceability: 1FNY7YN
Source Plant: Q-RIMIR MATAMORS MEXICO Part / Number Broadcast: 2395
Date Scanned: 12/23/2005 Time Scanned: 08:51:00 Scan Station: 06
Component Code: AL-IR-MODULE ASM-I/P Traceability: 7ZBCE57
Source Plant: M-MORTON-THIOKOL Part / Number Broadcast: 0900
Date Scanned: 12/23/2005 Time Scanned: 05:55:00 Scan Station: 04
Component Code: CB-SEQ NUM (FLEX) BODY ASM Traceability: 1100452
Source Plant: - Part / Number Broadcast: 1ZZ
Date Scanned: 12/17/2005 Time Scanned: 00:03:00 Scan Station:
Component Code: CF-SEQ NUM (FLEX) PAINT PROCESS Traceability: 2155281
Source Plant: - Part / Number Broadcast: 1WW
Date Scanned: 12/22/2005 Time Scanned: 04:32:00 Scan Station:
Component Code: CK-SEQ NUM (FLEX) GEN ASM Traceability: 2156305
Source Plant: - Part / Number Broadcast: 1PT
Date Scanned: 12/22/2005 Time Scanned: 18:00:00 Scan Station:
Component Code: CM-SEQ NUM (FLEX) GEN ASM Traceability: 2153997
Source Plant: - Part / Number Broadcast: 1PH
Date Scanned: 12/23/2005 Time Scanned: 02:54:00 Scan Station:
Component Code: CP-SEQ NUM (FLEX) GEN ASM Traceability: 2154351
Source Plant: - Part / Number Broadcast: 1GB
Date Scanned: 12/23/2005 Time Scanned: 03:47:00 Scan Station:
and, most interestingly, I can, given the type of part and part serial number, find out where the part was originally manufactured, and when.
by The Roadie » Wed Dec 08, 2010 2:58 pm
Philberto wrote:... I can, given the type of part and part serial number, find out where the part was originally manufactured, and when.
Now if you could only identify the original DESIGN TEAM and their pointy-haired BOSS for each of the maldesigned components, I'd give good money for that. :hissyfit: And then send out the Flying Monkey Hit Squad. :excited:
by Philberto » Wed Dec 08, 2010 3:01 pm
Bounty assigned and accepted. Research underway ;)
by themightysteveo » Fri Dec 10, 2010 2:36 am
That's a riot :cheers:
I'll send you my VIN when I get home to my truck...soon, soooooo soon :excited:
themightysteveo
by Philberto » Mon Jan 24, 2011 3:33 pm
*update* fixed! sending out histories now!
I am deleting posts with your VIN in them as I send out the histories.
by BSalty » Mon Jan 24, 2011 4:42 pm
Thanks Philberto!
Still didn't explain my spring swap tho. :scratch: Odd.
BSalty
by Regulator1175 » Tue Jan 25, 2011 12:07 am
VIN:
VIN:
Please and thank you.
by Iceman908 » Tue Jan 25, 2011 8:30 pm
VIN:
Thank you
Iceman908
by rgraboske » Wed Mar 16, 2011 6:36 pm
Let me know if you want me to take this over for you Philberto. I have access to the same system.
rgraboske
by Philberto » Sat Mar 19, 2011 2:01 am
Hey yeah if you want to run reports as well, just pm me when you run them so i can remove the posts with the VIN. I think I still have access, but have been a little preoccupied with looking for work.
:cheers:
by fevre_j » Mon Mar 28, 2011 4:18 pm
VIN:
Merci beaucoup!
fevre_j
by rgraboske » Mon Mar 28, 2011 5:18 pm
John,
PM sent :work:
rgraboske
by chevycrew » Sat Apr 02, 2011 2:02 pm
VIN:
1GNDT13SX22120365
I just bought it and some idiot peeled the RPO code sticker.
Thanks!
by fishsticks » Sat Apr 02, 2011 3:16 pm
chevycrew wrote:VIN:
1GNDT13SX22120365
Thanks!
Gratz on the purchase!
by rgraboske » Sat Apr 02, 2011 4:54 pm
For some reason my remote access isn't working today. I'll check it when I get to work on Monday :work:
rgraboske
by The Roadie » Sat Apr 02, 2011 5:05 pm
http://www.compnine.com says it has these RPO codes:
by chevycrew » Sat Apr 02, 2011 6:15 pm
The Roadie wrote:http://www.compnine.com says it has these RPO codes:
Thanks! Now I know I can find them by vin on that link.
rgraboske wrote:For some reason my remote access isn't working today. I'll check it when I get to work on Monday :work:
No worries.
by rgraboske » Mon Apr 04, 2011 2:39 pm
I have all of the warranty history pulled. If you send me a PM with your e-mail address, I'll send them to you.
As an aside, you have a really early build. It was sold out of Ypsilanti, MI on 7/9/01.
rgraboske
by djthumper » Mon Apr 04, 2011 2:50 pm
VIN: 1GNDT13SX62173802
Thanks
Larry
KC7QJO
by Flying Monkey » Sun Jul 10, 2011 12:25 pm
On stand by lol.
Flying Monkey
