It is currently Fri Sep 10, 2010 8:05 pm
View unanswered posts | View active topics
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: Maint. blues
PostPosted: Tue Mar 09, 2010 3:15 pm
Online
JamesDowning wrote:
Didn't your bottle have a nipple like RP?
Yeah, it did, but all I had was aquarium air-line tubing (1/8") which didn't work too well with the heavy weight gear oil.
bgwolfpack wrote:
There are stores in this part of our country that sell auto stuff. There called Auto parts Stores. They sell small little pumps that attach to the gear oil bottle with a length of hose connected for insertion into the hole. That way you can just pump it in form the bottom or the top.
Doh! *facepalm* I didn't bother to look for those when I went to Kragen (now O'Reilly). I knew there had to be an easier way to do the stuff... Oh well, it's done now anyways. Definitely something to buy before doing the rear diff though.
_________________
My Build Thread | This vehicle will eventually be a self-contained camping offroad vehicle... stay tuned for more mods.
Top
 Profile E-mail
PostPosted: Tue Mar 09, 2010 4:33 pm
Offline
bgwolfpack wrote:
Sounds like the rubber grommet is seized in place. You may need to use a pair of pliers. One on the dip stick and one (securely) on the pipe. Twist.
Edit: Add pic
Its bad like both my friend and i gave it all we had, and nothing happened, but twisting is the next move.
_________________
Top
 Profile E-mail
PostPosted: Tue Mar 09, 2010 4:44 pm
Online
I recommend a pair of gloves and a big set of vise-grips... make sure you flip that red tab first, then grab it by the base if you can...
_________________
Top
 Profile E-mail
PostPosted: Tue Mar 09, 2010 7:08 pm
Offline
Foosh, If Roadie hadn't have got himself a job...nough said
Posted for theroadie
Got it out yet?
_________________
Ran
Top
 Profile E-mail
PostPosted: Tue Mar 09, 2010 10:52 pm
Offline
Any tips for removing an o2 sensor that has been rounded off. Cant get a good grip on it period. Was thinking of tack welding a wrench to it or something, but hoping there is a better way.
It actually idles lower and runs a bit better with the wires cut, so it must have been shot.
_________________
God is Great, Beer is Good, and People are Crazy
06 TB-- 4.2L-- 3.73 w G80-- 2.5 Susp.-- 3 Body.-- 305/65/17 Pro Comp Xtreme MT-- 1.3 Adapters 6x5.5-- Adjustable Panhard bar-- Cut Fenders-- Bilsteins-- Rock Rails
Top
 Profile E-mail
PostPosted: Tue Mar 09, 2010 11:16 pm
Offline
You may be able to grind two sides down to fit a smaller wrench. I just changed mine and there seems to be ample metal. Which one is it?
_________________
Ran
Top
 Profile E-mail
PostPosted: Tue Mar 09, 2010 11:22 pm
Offline
upstream so not much room to work with. but good idea, keep em coming please....
_________________
Top
 Profile E-mail
PostPosted: Wed Mar 10, 2010 12:03 am
Online
Vise-grips should be able to grip it, then use a pry-bar to turn them if space is tight. Another helpful technique is to use a heat gun or torch to heat up the threads of the O2 sensor before trying to remove it. That's what I had to do on my last car, since whoever changed the sensor didn't use anti-seize when installing it.
_________________
Top
 Profile E-mail
PostPosted: Wed Mar 10, 2010 9:10 am
Offline
Will make a go with vice grips first. We had a torch on it for a good ten minutes since the edges were sketchy at first, but it didnt help.
_________________
Top
 Profile E-mail
PostPosted: Wed Mar 10, 2010 2:56 pm
Offline
I Like the idea of taching the wrench on it, done it a couple times, and looking at the amount of room you hvae there, it may be the best bet!
_________________
Wheeler's Off-Road Inc.
Top
 Profile E-mail
PostPosted: Tue Mar 16, 2010 8:08 pm
Offline
Any luck?? Just picked up one for my rig!! See how it goes tonight!!
_________________
Top
 Profile E-mail
PostPosted: Tue Mar 16, 2010 8:24 pm
Offline
I have been busy and it runs better with the wires cut so I keep putting it off. I scrubbed tar off and painted rails after winter sand blasting the paint off, but tomorrow should be great weather and I am making myself try it...Good luck.
_________________
Top
 Profile E-mail
PostPosted: Fri Mar 19, 2010 9:08 pm
Offline
Ok well my dipstick is loose, but it still won't pull out, like its locked into the trans...???
_________________
Top
 Profile E-mail
PostPosted: Fri Mar 19, 2010 9:10 pm
Online
Damn Tom... that sucks. I just checked mine before. It came right out without issue.
I am, however, noticing some coolant leaking from my truck. Looks like its coming from the radiator cap, think its a bad seal on the cap...
_________________
Top
 Profile
PostPosted: Fri Mar 19, 2010 10:21 pm
Offline
Have you tried tapping/hammering lightly on the stick towards the trans its self. There are a few light parts that it could catch on down inside if the stick is bent or warped. Is it the correct dip stick for the truck? Does it look identical to other pics? :scratch:
_________________
Ran
Top
 Profile E-mail
PostPosted: Sun Mar 21, 2010 10:49 pm
Offline
I'd hope its the right stick, looks like Brendan's too...
_________________
Top
 Profile E-mail
PostPosted: Sun Mar 21, 2010 11:29 pm
Online
Dont go around talking about my stick tom...
Thats okay, according to my dipstick, i had the perfect amount of oil, just a little dirty so i went to change it. Opened up the oil pan, took off the filter and let it sit for about 40min. Come to find out, a little over half a gallon of oil came out. Now how is this possible. Our trucks take 7qt with the change of filter. 4qt=1g. so that would mean i had ~3qt of oil in my motor? WTF?
No leaks, no pinging, no spills. :scratch:
I run AMSoil full synthetic 5w30.
Recommended change every25k miles. I only had 15xxx since the last change and changed the filter 5k ago (and topped it off then)
Iv dealt with AMSoil for many years and nvr run into this issue. None of my family mechanics can figure it out either. Just another weird issue with my truck :coffee:
_________________
The ONLY Superior Blue lifted tb
2.5" suspension; BDS 9500; 1.5" adapter 6x5.5
15x10 Procomp 8179; 33 x 12.5 Hankook Dynapro MT
Top
 Profile E-mail
PostPosted: Sun Mar 21, 2010 11:45 pm
Offline
GM recommends 25k between changes? I change every 5 at most.
_________________
Top
 Profile E-mail
PostPosted: Mon Mar 22, 2010 2:24 am
Online
Its not GM, its the difference with AMSOIL. AMSoil is the only true FULL synthetic oil. Its gauraunteed up to 25k miles before a change, obvi i wouldnt let it go THAT long. I know what im talking about when it comes to this stuff as well as alot of engine buiders in my area and they all agree, they dont know how THAT much oil would burn up, esp when the dipstick read that it was fine. It just doesnt makes sense, esp the fact that my motor was runnin on such little oil how there was no knocking or the motor didnt seize. This is my 3rd amsoil change on my truck, but the first time iv expierenced this. However, this is the first change since my truck has been lifted. Could offroading have something to do with it? Aswell as the deep water crossings that plague me with every trip?
_________________
Top
 Profile E-mail
PostPosted: Mon Mar 22, 2010 12:38 pm
Offline
Site Admin
Rank: Offroad Guide
Do you have something clogging the drain hole? Gunk could have become dislodged... which got stuck in the drain before the entire sump drained.
_________________
8-) JD.OFFROADTB.com | Build Thread | ExPo Build | YouTube Videos
Exploration is the essence of the human spirit.
Top
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: MSN and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB
