Independent heater system Eberspächer
by Karo » Fri Oct 04, 2013 4:32 pm
So I never have posted about my independent heater system. This is a historical modification that I have done some years ago.
The system is from Eberspächer and is called Hydronic B5WS. It simply heats up the motor water system and blows warm air inside through the heater core. It is installed to the water circuit and gets his power from my second battery system and from the main tank using the fuel for heating. So this is one of my personal favorite modifications. It helps me in the winter to get my front window free from ice. When on camping I mainly sleep in my car and with the heater it is really a nice thing to sleep warm when it is cold outside. It warms the motor before starting the car and it helps me to reduce my fuel consumption as I can switch to the autogas mode earlier and driving only with the propane/butan system.
Here is a schematic picture:
This is a overall view from under the car looking above, you can see the frame of the TB from the passenger side. I have chosen that location because the tubes are near the heater core to which they are connected.
You can program the times for heating and even cooling (ventilation) by various days and times with a small remote:
I have installed a additional thermostat for heating the inside first and after opening from the thermostat at 60 degrees it heats up the water circuit from the motor. Inside is a additional electric circuit installed that is connected to the blower motor and the actuators for choosing the correct adjustment when removing the ice from the front window. So that the air blows directly to the window if needed.
You can see the thermostat that is connected to the heater core and the water cicuit here:
Details to the Eberspächer system can be found in english here:
http://www.eberspacher.com/products/heating-products/water-heating/hydronic-5.html
Are there any similar systems in the states?
Karsten
Karo
by mikekey » Fri Oct 04, 2013 5:35 pm
Ok wow, that's pretty cool right there. I can think of places where that could come in handy.
by RyansTBLS » Fri Oct 04, 2013 6:27 pm
Wow! :awesome: Has anyone told you you're a genius before? :poke: :flex dirty:
RyansTBLS
by dvanbramer88 » Fri Oct 04, 2013 7:12 pm
Thats a pretty cool little system. Combines electric heat with a block heater in one unit. That must be really nice camping out in the cold. All warm and toasty inside without having to run the motor.
by ErikSS » Fri Oct 04, 2013 8:50 pm
This topic is above my pay grade. haha I think it's fricking awesome, but not something I can wrap my tiny brain around!
by Trail X » Sat Oct 05, 2013 12:51 am
dvanbramer88 wrote:Thats a pretty cool little system. Combines electric heat with a block heater in one unit. That must be really nice camping out in the cold. All warm and toasty inside without having to run the motor.
Not electric heat, it burns gasoline.
On our cranes we use a slightly more all-in-one design by webasto. Similar concept sorta, minus heating the engine and coolant.
Very cool Karsten. I like all these goodies you have hidden in your truck. I think dirty anton would appreciate this since I know he sleeps in his truck.
by v7guy » Sat Oct 05, 2013 2:06 am
Karsten, you have some really odd things on your truck and I really like it. lol
by Karo » Sat Oct 05, 2013 7:40 am
Thank´s to all for responding.
@James - yes Webasto has same kind of products like Eberspächer. I think in your cranes are some kind of airtop heater. Did your cranes run with diesel or gasoline?
Overall I really would like to meet up with you guy´s and have a look at your Trucks to get some more ideas of what can be done.
I already have some more ideas for some functional gimmicks, but all needs time.
Karsten
Karo
by Trail X » Sat Oct 05, 2013 11:39 am
Our cranes burn diesel. Another key difference.
by Cable810 » Sat Oct 05, 2013 6:02 pm
That's Awesome!!
by dirty anton » Sat Oct 12, 2013 5:42 am
Awesome!
dirty anton
